3 inch Double Fixture Fitting with 2 inch reducers?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Steve1911, Nov 23, 2013.
  1. Steve1911
    Steve1911 New Member
    Nov 23, 2013
    Georgia
    I am fixing a poorly done single to double vanity conversion. I have a 3 inch stack (3 inch drain and 3 inch vent pipe, inline) in the wall that I will be attaching the vertical hubs of a Double Fixture Fitting, but I need 2 inch hubs on the horizontals to stub out the sink drains with 2 inch (or 1 1/2 inch?) abs. The smaller diameter pipe is also necessary to go through my wall studs.
    Is there any reason I should not cement 2 inch reducers to the 3 inch horizontal hubs of the Double Fixture Fitting?
    Crude diagram of my elusive Double Fixture Fitting. Thanks for the help.
    ll
    2= =2
    ll
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Have you ever seen a 3" double fixture fitting? If they exist, it is not something we normally see.
  4. Steve1911
    Nov 23, 2013
    Georgia
    Thanks for the reply. This is what I found from grainger 3 inches all around?
    http://www.grainger.com/product/MUELLER-INDUSTRIES-Double-Fixture-Wye-3GUR6?s_pp=false
    If that doesn't work with 2 inch reducers on the horizontals, or the sizing is not actually what I think it is, is there anything wrong with buying a 2 inch Double Fixture Fitting and using reducers (3 inch to 2 inch couplings) to fit my vertical 3 inch vent and 3 inch drain to the 2 inch Double fixture fitting?
  5. hj
    No problem using the reducers.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I have to back-pedal a bit on my comment, as the 3" double fixture fitting is pretty much unheard of in the stores around here. ABS drain piping is pretty much unheard of here also, but that is a whole different topic.
    If you had such a fitting, there would be no reason you could not use reducers on the inlets. You can always go from a small trap arm to a larger drain, but never the other way around.
  7. Steve1911
    Nov 23, 2013
    Georgia
    Thank you both.
  8. Steve1911
    Nov 23, 2013
    Georgia
    Thanks for the information so far. This is my plan and I just would like you guys to check it out and critique if necessary. Specifically, will the 3"-1.5" flush bushings be acceptable and are the trap arm lengths OK. I like the 1.5" trap arms as opposed to the 2" in my original post due to the wall studs being 2x4's. I will also re route the supply lines to come out of the wall instead of the floor.
  9. Terry
    Aug 17, 2004
    I used to install a lot of them. With the new 3" flush valve toilets, I prefer to plumb them seperately now.
    It should be fine for the lavs there.
  10. Steve1911
    Nov 23, 2013
    Georgia
    Excellent. My worry was the 1.5 inch flush bushings in the inlets of the double fixture fitting would mess with the water flow but it seems I'm good to go.
    Time to order the parts and get to work. My goal is to make it look as good as some of the pictures I've seen here. You guys are a great help. Thanks
Similar Threads: inch Double
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Support studs in bathroom need new how do i thread 2 inch pvc pipes thru them Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Replace 2 inch x3 and one 2 1/2 to ball valve tips Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Two inch vent or one and a half vent? Aug 13, 2016
Plumbing Forum, Professional & DIY Advice Bathroom pipes go from 3/4 to 1/2 inch for total of 8 feet. will I benefit if I convert to 3/4 ? Aug 7, 2016
