3" drain connection questions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by troyce1, Aug 4, 2014.
  1. troyce1
    troyce1 New Member
    Aug 4, 2014
    I am trying to make sure I correctly connect 3" drain pipes that I am re-running in my house.
    On a 3" drain line that is running horizontal, can I use a 45 elbow at an angle and connect that line with the main stack with a "Y" fitting.
    Also can I use medium turn 90's in the waste line, or do they all need to be long sweep 90's? If not when am I allowed to use medium 90s?
    And last question, for the toilet, can i use the floor flange tied into a 90deg street elbow? Using a 45 with a wye is huge, and ill have to build a bulkhead.
    The attached picture of the stack in the basement:
    The bottom san tee with nothing connected yet, is for the washer dryer.
    The wye above that is for the cleanout.
    The tee above that that has a 2" line connected is for the kitchen sink
    the wye above that, is what I plan to run my second floor toilet into. I wanted to run the drain at an angle so that it is above the washer dryer, and I can keep it tighter to the ceiling. I was going to run a 45 off the 3" line, and into the wye. The attached drawing demonstrates how this would run.
    Thanks for any advice, I just want to make sure I'm on the right track.
  2. hj
    Until we know HOW you are going to run the rest of the piping and how everything will be vented, there is no way to tell if what you have is going to correct or not.
  4. troyce1
    troyce1 New Member
    Aug 4, 2014
    The existing bathroom venting/piping is not going to be changed in location, or sizing. The kitchen sink has its own 2" vent as well
    The new bathroom. In order to add the vent, the only two ways I can come up with, without dropping below the joist line, are to run the street elbow from the toilet flange into the "Y" as shown, with a new 3" vent coming off the back side of the "Y", and then running up the back side of the wall behind the toilet. (Dry fitted as shown in the Undersidebathroom pic.
    Or I could switch the elbow show on the top of the vertical drain, with a "T" and run a 3" pipe across and up the back side of the vanity, and tie the vanity vent into the 3" vent. This plan however would probably drop the toilet waste line below the joist line, and I am trying to avoid additional bulkheads.
    Using a 3" combo from the toilet flange will also drop me below the joist line.
    Using the "Y" as shown for the toilet, and running a seperate 2" vent for the vanity and shower seems to be my best option.
    I attached an updated pic of the basement tie-ins also.
Similar Threads: drain connection
Plumbing Forum, Professional & DIY Advice PLZ HELP-kitchen drain connection problem Jan 15, 2016
Plumbing Forum, Professional & DIY Advice Drain connection for a commerical ice bin Dec 21, 2015
Plumbing Forum, Professional & DIY Advice Drain line connection Sep 7, 2015
Plumbing Forum, Professional & DIY Advice Water heater Pressure Relief drain connection Sep 2, 2015
Plumbing Forum, Professional & DIY Advice Leaky P-Trap Tailpiece connection to Drain May 24, 2015
