3/8 or 1/2 supply angle stops... what do you use?
whackit
Los ANgeles
So I have always installed 3/8 angle stops.. no particular reason. I recently had a job with an, um, 'particular' customer. He made me swap out all of the 3/8 stops for 1/2 inch ones and told me 'nobody uses 3/8 anymore'. I explained that the lines are the same size etc but he had to have his way. Okay no biggie, easy swap. But my question is...
What do you use? 1/2 or 3/8?
Always 3/8"
I don't know any plumbers that install 1/2"
And most new faucets that come with their own supply lines only come with 3/8".
Send him hear and I will educate him.
1/2" out of the wall and 3/8" comp to the lav.
But sometimes I do see 3/8" comp, 1/2" comp and 1/2" IP shutoffs needing 1/2" FIP supplies too.
FullySprinklered
Georgia
3/8.
I try to keep 1/2 x 3/8 comp. adapters for those times I run into 1/2.
Anyone using 1/2 in stops probably has flame decals on his Yugo.
There are few things in today's flow restricted requirements that could benefit from a full-port 1/2" device. Way back when, maybe, but it's been decades.
Dj2
California
For me they're all the same, just like threaded angle stops vs compression vs soldered.
3/8" is the most convenient though.
Dj2
California
By making sure the washer inside is in good condition. Use new connectors every time you install a new angle stops.
The 1/2" outlet angle stops will eventually disappear.
