3/4" vs. 1/2" supply to shower?
Discussion in 'Shower & Bathtub Forum & Blog' started by knoctor, Oct 31, 2009.
  1. knoctor
    knoctor New Member
    Oct 17, 2009
    dentist
    Dayton, OH
    Doing a remodel. Existing 1/2" supply lines to shower. I can replumb with 3/4" supply, but shower head is to a standard 1/2" stubout. Is there any advantage to converting to 3/4" supply line from main, or is the 1/2" a limiting factor? I'm installing ZOE industries Polaris II double shower head.
  2. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
  4. hj
    pipe
    IF your shower valve will only flow as much, or less, than a 1/2" pipe can supply, which is very likely, then there is no advantage to using 3/4" supply lines.
  5. jadnashua
    A 3/4" valve can flow as much as twice as much water as a 1/2" version of similar design. But, whether you need it or not depends on how much water the heads need to provide decent spray. And, unless you have 3/4" supply lines, a 3/4" valve will only give you marginally better flow if fed with a 1/2" line, if at all.
  6. hj
    valve
    A 3/4' ceramic seat valve has openings LESS than half the size of a 3/4" pipe. First you take away the space needed for the rim of the seal, then divide the remainder into four pie shaped pieces. Two of them are open for water to flow and two are closed for shutoff purposes. Then take away the space needed for the webs between the quadrants and you are left with an area about the same, and maybe less, than a 1/2" copper line. Take a stem out sometime and measure the area of the two openings.
  7. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    1/2" vs 3/4"
    I would switch the lines to 3/4" for sure unless you are piping in 1/2" copper.
    Compare the inside measurement of a pex fitting 1/2" vs 1/2" copper and you will see a big difference.
    If you are re doing your bathroom do it right and re pipe it with a new home run. Insulate the pipes and strap them down.
    Good Luck.
Similar Threads: supply shower
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Delay with hot water supply in shower Dec 9, 2014
Shower & Bathtub Forum & Blog New tub shower combo supply question Apr 17, 2014
Shower & Bathtub Forum & Blog 3/4 inch supply line to master bath, but 1/2 inch line at shower valve? Feb 12, 2013
Shower & Bathtub Forum & Blog 3 step Delta diverter to supply two shower heads (yay or nay?) Aug 9, 2012
