3/4 bath remodel in basement
Discussion in 'Remodel Forum & Blog' started by ccbrands1, Dec 20, 2006.
  1. ccbrands1
    ccbrands1 New Member
    Jul 19, 2006
    Drain rough in for a 1/2 bath in basement.
    1 1/2" vent at the vanity drain line.
    Toilet drain is upstream of the vent.
    Drains beneath concrete.
    I want to add a shower into the mix.
    I plan to install a 3 x 2 wye after the vent for the vanity drain line.
    Is it ok to run the shower drain line in this way?
    Or should it be tapped in between the vent and the toilet?
    Code references would be great, but general comments on how either way would effect drainage would also be good.
    thanks
  2. ccbrands1
    Jul 19, 2006
    so to elaborate, can I place my 3 x 2 wye in the spot in the attatched diagram?
  4. ccbrands1
    Jul 19, 2006
    diagram here
  5. prashster
    prashster New Member
    Dec 7, 2005
    My nonpro opinion is that it will work. I'd also run run a shower vent off the shower branch drain b4 it hits the main line. This means running the shower branch drain under a wall b4 it hits the main drain.
    Toilet venting confounds me. I know it's advisable for each fixture to have it's own vent, but I know there are exceptions and the wet vent you have might be permissible for the toilet. I'd check though.
    That's just me, though.
    Also, the 'tee' that connects the sink vent to the main line should be a wye, and the 'tee' that connects the sink trap arm to the vent/drain should be a sanitary tee or better.
  6. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    distant? close?
    --> Distances determine whether a vent can be used for two fixtures or only one.
    so far so good, all is normal. Toilets are always the farthest upstream, and the first vent in the system is the toilet's vent.
    not sure what this means precisely.
    perfectly normal to do it this way. Totally not good to do it the opposite way that you described, i.e. between the vent and the toilet.
    The big unanswered questions are distances. This is important; it determines whether a vent can be used for two fixtures or only one.
    david
  7. ccbrands1
    Jul 19, 2006
    sorry...i meant that the drains are underneath concrete...you probably assumed this considering it is in a basement
    toilet drain is about 2 - 3 feet from vent
    shower drain is about 4 - 5 feet from where it will tap into the main drain line.
    shower drain tap on main line can be within 1 foot of the vent if needed.
    please advise if these distances would be sufficient.
Similar Threads: bath remodel
Remodel Forum & Blog Tiny bathroom remodel Aug 28, 2016
Remodel Forum & Blog Herb's Bathroom Remodel Jun 27, 2015
Remodel Forum & Blog Bathroom Shower Remodel Jul 5, 2014
Remodel Forum & Blog Bathroom remodel: underfloor heating and related decisions May 13, 2014
Remodel Forum & Blog Big problems arise after bathroom remodel: advice needed May 8, 2014
