3/4 ball valves.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hammerslammer, Aug 21, 2007.
  1. hammerslammer
    hammerslammer New Member
    Dec 10, 2005
    I'm still preping for my 4 unit water heater conversion from lowboy gas to electric. I want to add some shutoffs while I have the plumber out and i'm looking to buy 24 3/4" ball valves. The plumber doesn't care but i prefer threaded in case i have to mess with something in the future... Is there an online source that i can buy 24 valves and is it a good idea to buy them this way. Thanks again... Any general advice on buying valves??
  2. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    You're not going to save a lot of money shopping online but www.grainger.com carries a ton of plumbing, electric, and other industrial items. Get 1/4 turn ball valves.
    I'd also to with regular sweat valves, you're not making anything easier using threaded valves. You would still need to un-sweat the pipe from the male adapter or cut the pipe to change the valve since trying to loosten one end would just tighten the other. All using the IPS valves is going to do is cost a few dollars more in labor and materials.
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Cincinnati OH
    Also ball valves last longer than standerd valves.If you used ips valves,
    would put unions on at least one side of the valve.That way you could
    at least twist off. But I would sweat valves on and if they go bad 10 yrs
    cut it out and use slip couplings.
  5. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    I didn't even think of unions as I rarely see them on copper, that would work. But you have to buy 24 unions and 24 brass shoulder nipples as well, it would probably cost another $150 in material and an extra hour of labor to install them. For that money buy a cheap torch, some basic plumbing stuff, a piece of pipe, some fittings, and learn to solder.
Similar Threads: ball valves
Plumbing Forum, Professional & DIY Advice Welding PVC ball valves Jun 15, 2016
Plumbing Forum, Professional & DIY Advice PEX ball valves - Lead vs. Lead Free Mar 31, 2015
Plumbing Forum, Professional & DIY Advice Can all brass full port ball valves be used for hot water? Sep 20, 2012
Plumbing Forum, Professional & DIY Advice Red & White 1/4 Turn Ball Valves STILL OK to use? Jan 30, 2012
Plumbing Forum, Professional & DIY Advice Ball Valves - Forged Brass vs Forged Bronze Jun 11, 2011
