2nd Floor Washing Machine Puts Water Into 3rd Floor Sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by molo, Aug 9, 2010.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Hello,
    I am wondering what are the most common causes of something like this before I start to tear things apart to troubleshoot. When the second floor washing machine is running it forces water into the third floor sink drain into the sink.
    Thanks,
    Molo
  2. jimbo
    jimbo Plumber
    Well, the only thing I can see that would cause that is that the drain the washing machine goes into is plugged, partially. The pump in the machine is strong enough to send water up to the third floor. I am surprised that it does not overflow the drain on the second floor........is the washing machine connected to an open fitting, or is it "sealed" into a pipe??
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Maybe a backflow preventer on the second floor laundry and a blockage further down the line?
  5. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Thanks for the reply,
    The washing machine goes into an open drain and is not sealed.
  6. hj
    quote: The washing machine goes into an open drain and is not sealed.
    Then it is IMPOSSIBLE for it to develop ANY pressure, much less what would be needed to force the water UP 10 feet or so to the third floor. Your analysis is faulty.
  7. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Pressure can very definitely be developed in drain pipes if the venting is not up to snuff. Probably the sink upstairs does not have adequate venting, so the trap contents are being
    forced into the sink by the pressure from the washer drainage.
Similar Threads: Floor Washing
Plumbing Forum, Professional & DIY Advice Floor drains verses washing machine pan Sep 7, 2016
Plumbing Forum, Professional & DIY Advice Drain washing machine on first floor to laundry tub in basement? Jul 29, 2013
Plumbing Forum, Professional & DIY Advice floor drain/ washing machine hose in laundry room May 8, 2012
Plumbing Forum, Professional & DIY Advice Basement Plumbing for Washing machine, Floor Drain and sink Apr 7, 2010
Plumbing Forum, Professional & DIY Advice Washing machine P-trap question, under floor? Feb 19, 2010
