2nd floor shower drain water level?
Discussion in 'Shower & Bathtub Forum & Blog' started by spinman, Mar 28, 2010.
  1. spinman
    spinman New Member
    Mar 28, 2010
    Jupiter, FL
    Hello,
    this is my first post and its probably a very basic question. I hope.
    I am building a new shower on the 2nd floor. I'm at the point where I screwed down the top part of the drain on the liner. Looking down the 2 inch pipe, I saw that the water level is 6-7 inches below the liner. My question is whether it is normal for the water level to be that high. I have not tested letting water run to see if it drains or if it just backs up. Before I test that, I wanted to ask, hoping for a positive answer. This is my first try at building a shower.
    Thanks for any info,
    Robert/spinman:confused:
  2. jc60618
    jc60618 DIY Junior Member
    Dec 12, 2009
    Apprentice Plumber
    Chicago
    How far below the floor is the p-trap? If you ran the drain line with proper pitch you have nothing to worry about.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    You have a trap under the shower, so you should always see water when you look down.
  5. jadnashua
    The purpose of the trap is to block sewer gasses from coming into the room. To work, it needs to be full of water. The level depends on where the trap is. Sounds about right.
  6. hj
    The normal water level will be wherever the "P" trap is set. There is no way for us to tell you if the water level is too high or low because we do not know that dimension.
  7. spinman
    spinman New Member
    Mar 28, 2010
    Jupiter, FL
    Thank you! Thank you! Thank you!
    Your replies put my mind at ease. This space upstairs has been waiting for me to install bathroom/shower for the past 20 years. I know this because my wife reminds me. The floorboards/plywood were already there when I bot the house and I don't know enough about traps under the flooring. By your information I now understand that there "must be a trap" that holds some water level to prevent fumes from burping back up. So, if I got this right, as the water flows down the drain, the water gets pushed down (gravity) and, about, the same level of water remains above the trap. I really want to thank you for helping me understand this. This site is very useful and helpful.
    Robert/spinman
Similar Threads: floor shower
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
Shower & Bathtub Forum & Blog Appropriate shower curb on concrete floor Sep 22, 2016
Shower & Bathtub Forum & Blog Basement Floor Drain as Shower Drain? Mar 9, 2016
