2nd floor laundry
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bkprod, Feb 20, 2007.
  1. bkprod
    bkprod New Member
    Feb 20, 2007
    I would like to put a washer/dryer on the 2nd floor of our house. My plan is to build a small platform that the units will sit on, to allow for an overflow drain under the washer.
    I am trying to safegaurd against any potential water problems, so I have purchased an emergency automatic shut-off valve, along with a water sensor to sit in the washer tray. My issue is with 2 things: 1) My licensed plumber suggests running the overflow drain through an outside wall, where it will simply run into a gutter on my roof. Does that sound right?
    2) Because of the location of the laundry, our plumber suggests using an AAV (air-admittance vent) instead of trying to run a long complex vent line up through the roof. Is this generally accepted? All plumbing (including the aav)will be accessible behind a knee-wall, under the roof line.
    Thanks!!
  2. dgreen1069
    dgreen1069 New Member
    Feb 15, 2007
    Northern VA.
    I am strickly a beginner, but I am pretty certain there is no problem using a AAV in your situation. On the other hand, I an also pretty certain that you cannot allow waste water to exit your house like that. Your washer would be spewing gray water and most states do not allow you to dump that outside.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'd suggest you consult another plumber, and make certain he is licensed. I can't imagine a licensed plumber suggesting you drain the washer into your roof gutter! The AAV will work OK, but it does have to have easy access in case of failure. The real problem is with the drain. The drain requires a 2" drain line, a trap, and a vent. The AAV takes care of the vent requirement, but that's all.
  5. bkprod
    bkprod New Member
    Feb 20, 2007
    Well, again...the drain I am speaking of is merely an overflow drain in a pan that the washer sits on only used in the event of a leak. So the chance of any wash water at all exiting through this is remote (as I also have a automatic shut-off valve and water sensor in the drain pan).
    I will of course have the main drain of the washer plumbed properly according to our local code.
  6. dgreen1069
    Feb 15, 2007
    Northern VA.
    I knew what you meant. I have a second floor laundry and my washer sits in a pan with a drain. I guess for your purposes it might be OK to route the drain outside, but it won't be to code. What will you put over the pipe to keep critters out?
Similar Threads: floor laundry
Plumbing Forum, Professional & DIY Advice Second Floor Laundry Floor Drain Pitch Jan 20, 2016
Plumbing Forum, Professional & DIY Advice 2nd floor laundry, draining concerns (pics) Mar 16, 2015
Plumbing Forum, Professional & DIY Advice Floor drain in laundry room? Mar 9, 2015
Plumbing Forum, Professional & DIY Advice Floor drains below laundry, dishwasher, fridge? Jan 5, 2015
Plumbing Forum, Professional & DIY Advice Drain washing machine on first floor to laundry tub in basement? Jul 29, 2013
