2500 gal Storage Tank installation
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rvcolt, Mar 6, 2009.
  1. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    I am installing a 2500 gal backup storage tank to my well. Would it be a good idea to plumb and wire it so that I can run either one of three options.
    1. The well to house. In case of problem with the tank.
    2. The well through the tank to house.
    3. The tank alone to house. In case of well problems.
    Also which pump should I use? I think I need to use a float valve in the tank along with a timer because my well only produces about 4 gpm and I don't want to pull the water level down too much. I have had one cave in already but was able to pull the pump up and take out a 30ft section of pipe.
    I would appreciate any advice.
    Jerry
  2. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    I'm assuming he's burying it if he's had one cave in already. So I'm thinking color doesn't matter?
  4. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    Sorry, my bad. A tank did not collapse the wall of my well fell in on top of the pump. I was able to pull the pump up past it. It is black.
  5. Gary Slusser
    Retired
    Have you looked into fixing the well?
  6. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    The well is working. I am putting the tank in for back up just in case I have anymore problems with the well.
  7. Gary Slusser
    Retired
  8. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    Yes, a bypass system is what I had in mind. I will research the mercury float switch. The tank is black.
    Thanks
  9. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    Thanks. Yes, I plan to do the work myself.
  10. Gary Slusser
    Retired
    Casing out the well should be able to be done for not much more, if not less, than this 2500 gal tank, pump, pressure tank, float switches plumbing etc. and wouldn't cause water quality problems that a cistern does. And then the well wouldn't be capable of caving in again as it can now.
    Are you planning on how to clean and sanitize the tank? If you have any iron you'll have rust build up from the water line down in the tank and in TX, the heat and water temp is conducive for slime and other growth in the tank. You may have to buy water treatment equipment to treat the water.
  11. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    I was told that do to the diam. of the well no casing could be done, I would have to drill another. That's why I am doing this.
    I already have the tank sitting on a pad. I have a filtration system in place. Don't have a rust problem. I plan on treating it with clorine (sp).
  12. rvcolt
    rvcolt New Member
    Mar 6, 2009
    Canyon Lake Texas
    Thank you. That is the thing I need the most help with. I have done electrical work but I am having trouble figuring out how to wire this. Any advice would really be appreicated. A diagrahm is most needed.
    Jerry
Similar Threads: 2500 Storage
Pumps and Tanks Well Forum & Blog. Water is life. 2500gal Storage tank to house what pump? Apr 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Advice on Plumbing 2500-gal Water Storage Tank into Existing Well System May 9, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Installing 2500gal above ground tank. Do I need a concrete pad? Sep 22, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Tuesday at 6:26 AM
Pumps and Tanks Well Forum & Blog. Water is life. Yet another Storage tank CSV setup Question Jan 8, 2017
