25"x22" Stainless drop-in sink in 27" sink base cabinet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by John414, Aug 27, 2010.
  1. John414
    John414 New Member
    Feb 9, 2006
    New York
    I'm redoing the kitchen counter and under-counter cabinets in a house with limited space. Can I use a 27" wide sink base cabinet for a standard 25" x 22" stainless steel drop-in sink? If I have to use a 30" wide sink base cabinet, the sink will be not be centered on a window and access will be partially obstructed by existing cabinets.
  2. jadnashua
    Check the drawing, but my initial guess is no. It depends on the actual interior dimensions. If that 25" is interior, not exterior, then no. If it s exterior (which includes the lip), then yes.
  4. jimbo
    jimbo Plumber
    Check some Elkay or Dayton specs. It would be close. The inside measurement of a 27" cabinet is 26". The 25" drop in measures 25 outside edge of flange. The sides of the bowls are probably about 22" so it would be tight but doable.
  5. hj
    If you can mount the sink before installing the top it will work, otherwise you will have a very difficult time installing the side clips on the sink.
Similar Threads: 25x22 Stainless
Plumbing Forum, Professional & DIY Advice Brass or stainless constant pressure manifold? Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Ti-Krome Stainless Tubotron pipes Oct 15, 2016
Plumbing Forum, Professional & DIY Advice Top mount stainless sink Oct 15, 2016
Plumbing Forum, Professional & DIY Advice PVC, Braided Stainless Steel, Braided Polymer May 27, 2016
Plumbing Forum, Professional & DIY Advice HD Everbilt Corrugated stainless steel water connectors Aug 6, 2015
