240v wall thernostat works, but...
Discussion in 'Electrical Forum discussion & Blog' started by Ken Tannenbaum, Oct 28, 2010.
  1. Ken Tannenbaum
    Ken Tannenbaum New Member
    Feb 22, 2007
    I installed two baseboard heaters running off a 240v bi-pole thermostat and first wired it incorrectly blowing the circuit. The short happened at one of the radiators, not the thermostat. Now it's wired right and works, except that the instructions with the thermostat say it should make a clicking sound when it goes on, which it doesn't do. Is there a chance I damaged the thermostat? And could that be dangerous? Thanks!
  2. hj
    Does it work properly? IF so, then you did not damage it, regardless of whether you hear the contacts click or not. If the contacts did NOT open, or close, which creates the "click" the heaters would either not turn on or not turn off.
  4. Ken Tannenbaum
    Feb 22, 2007
    It's working fine so thanks for the advice....wish I was working!
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Switches are supposed to have a "snap action" so the arc during switching doesn't last too long. They use little magnets and springs to do this.
    I guess it's possible that this t'stat doesn't have this snap action anymore and so it won't last long. Can't say for sure, though.
    One way to check this would be to put an AM radio nearby tuned between stations. Arcs radiate radio waves and a drawn out arc should sound like a crashing sound for a half second or so, rather than just a 'pop' sound.
  6. jadnashua
    The switch has two poles, but breaking either one will cause the heater to stop working. One of them could be welded closed, and that could prevent the two from snapping back...it would depend on the construction of the switch. Or, it could be working fine. You could find out if that is the case with a meter. With the power off, the connection between one side of the switch and the other should be open on both poles. Or, with the power on, measure from the output of one side to the input of the other (do it both ways). If it is zero, the pole is open, if it reads 240vac, that pole is welded shut.
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    With the contacts closed confirm that you have less than 30 millivolts across those closed contacts with rated current flowing through them.
    More than 100 mV is bad.
    Open contacts should have 240 v across them.
  8. Ken Tannenbaum
    Feb 22, 2007
    Thanks for the useful tips....I'll get to it this weekend without a doubt.
Similar Threads: 240v wall
Electrical Forum discussion & Blog Wiring Multiple Wall Thermostat Controlled (Cadet) 240v Baseboard Heaters Apr 24, 2012
Electrical Forum discussion & Blog Noma fan forced wall heater 240v Mar 12, 2011
Electrical Forum discussion & Blog 240v and 2 circuits Oct 29, 2016
Electrical Forum discussion & Blog 240v breaker serving two heaters Sep 13, 2016
Electrical Forum discussion & Blog 240v circuits and using a white wire as a hot Apr 24, 2016
