240v 2 pole grounding switch to receptacle
Discussion in 'Electrical Forum discussion & Blog' started by RileyD, Apr 8, 2009.
  1. RileyD
    RileyD New Member
    Apr 8, 2009
    For the convenience of winterizing and child safety reasons I need to hook a 10g 3wire with a ground (4 wires) to a (grounding 2 pole on/off switch) and from there to a (240v 2-pole 3 wire grounding receptacle) so I can plug in an irrigation pump and turn it on and off with the switch.
    Thanks Riley
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Sounds like a good idea.
    Curious. Why the 4-wire feed?
  4. RileyD
    RileyD New Member
    Apr 8, 2009
    That's the wire that was available at the site. Riley
  5. RileyD
    RileyD New Member
    Apr 8, 2009
    Ps; so how do I hook it up, Pete? Riley
  6. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Oh.
    First off, ignore the white wire in the feed. You do not need it.
    Grounding everything is assumed, including the switch.
    The two hot wires of the feed to L1 & L2 (LINE) on the switch.
    The two hots to the motor to T1 & T2 (LOAD) on the switch.
    If the switch is not marked you'll have to figure out which two screws are line and which two are load.
  7. RileyD
    RileyD New Member
    Apr 8, 2009
    Thanks Pete, and I'll think twice about getting an Advanta credit card.
Similar Threads: 240v pole
Electrical Forum discussion & Blog How To Wire a Square D QO220GFI 240v, 20-amp Double Pole Breaker Jan 26, 2015
Electrical Forum discussion & Blog 240v single pole? Jul 20, 2007
Electrical Forum discussion & Blog 240v and 2 circuits Oct 29, 2016
Electrical Forum discussion & Blog 240v breaker serving two heaters Sep 13, 2016
Electrical Forum discussion & Blog 240v circuits and using a white wire as a hot Apr 24, 2016
