2008 NEC/ Closet Lights
Discussion in 'Electrical Forum discussion & Blog' started by alannaimee@charter.net, Jan 14, 2011.
  1. alannaimee@charter.net
    alannaimee@charter.net New Member
    Jul 9, 2007
    Helicopter Pilot
    East TN
    Gentlemen,
    I'm in the planning stage of opening up under the interior steps for storage/ closet area. I have a 2005 NEC, which says (if I'm reading right) that recessed fixtures are allowed as long as the bulb is enclosed.
    Anyone know if the 2008 NEC (which my city uses) allows the same?
    Thanks for your time
    Alan
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    410.16 Luminaires in Clothes Closets.
    (A) Luminaire Types Permitted. Listed luminaires of the following types shall be permitted to be installed in a closet:
    (1) A surface-mounted or recessed incandescent luminaire with a completely enclosed lamp
    (2) A surface-mounted or recessed fluorescent luminaire
    (3) Surface-mounted fluorescent or LED luminaires identified as suitable for installation within the storage area
    (B) Luminaire Types Not Permitted. Incandescent luminaires with open or partially enclosed lamps and pendant luminaires or lampholders shall not be permitted.
    (C) Location. The minimum clearance between luminaires installed in clothes closets and the nearest point of a storage space shall be as follows:
    (1) 300 mm (12 in.) for surface-mounted incandescent or LED luminaires with a completely enclosed light source installed on the wall above the door or on the ceiling
    (2) 150 mm (6 in.) for surface-mounted fluorescent luminaires installed on the wall above the door or on the ceiling
    (3) 150 mm (6 in.) for recessed incandescent or LED luminaires with a completely enclosed light source installed in the wall or the ceiling
    (4) 150 mm (6 in.) for recessed fluorescent luminaires installed in the wall or the ceiling
    (5) Surface-mounted fluorescent or LED luminaires shall be permitted to be installed within the storage space where identified for this use
Similar Threads: 2008 NEC/
Electrical Forum discussion & Blog online NEC 2008: a printing tip May 21, 2010
Electrical Forum discussion & Blog 2008 nec question. May 9, 2009
Electrical Forum discussion & Blog Anyone know if there are new ARC FAULT requirements in NEC 2008? Dec 24, 2007
Electrical Forum discussion & Blog The new 2008 nec. Sep 26, 2007
