2 wire heating system
Discussion in 'HVAC Heating & Cooling' started by JJLJr, Nov 5, 2007.
  1. JJLJr
    JJLJr New Member
    Oct 29, 2007
    Rhode Island
    I recently purchased a house and want to replace the Honeywell T87A 1000 thermostat with a programmable one. I purchased a Honeywell RTH6300B "5-2 Day" thermostat. When I removed the old t'stat, I noticed that there were only two wires, a black and a white. I traced the wiring back to the boiler and found a splice with the black connected to a red and white to white.
    Can I merely connect the existing black (red) wire to R and the white to W?
    Thanks for the help.
  2. jadnashua
    Yes. The fan on/auto switch will not work since there is not a wire to the furnace for its control, though.
  4. JJLJr
    JJLJr New Member
    Oct 29, 2007
    Rhode Island
    Is that a problem? I have an oil fired burner with forced hot water. How would the fan on/auto affect the system?
  5. jadnashua
    That's probably why they didn't run more wires! The fan control is for forced air systems. It shouldn't matter at all. Note, some of the smart thermostats have internal switches to customize it to the type of heating system you have. If yours does, make sure to set them properly.
Similar Threads: wire heating
HVAC Heating & Cooling I absolutely need to use a common wire to install my Nest...which is the common? Dec 7, 2016
HVAC Heating & Cooling Another adding the C wire thread (to WiFi thermostat) Jul 6, 2016
HVAC Heating & Cooling Wiring diagram for furnace relay & thermostat common wire May 26, 2016
HVAC Heating & Cooling Help with adding common wire (with wiring diagram) Jan 10, 2016
HVAC Heating & Cooling Adding C wire to Furnace Nov 25, 2015
