2 Valves on one zone?
Discussion in 'Irrigation / Sprinkler Forum' started by dbinaz, Apr 27, 2007.
  1. dbinaz
    dbinaz New Member
    Apr 27, 2007
    Is it ok to control 2 valves from 1 zone? Seems my "installer" took some shortcuts. Or should it be one valve per zone?
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    It's usually 1 valve per zone. If you have two valves, then you are really controlling 2 zones at once. The drawback to this is that you may not have adequate water pressure to work 2 zones at once. Are all the heads popping up and have good flow? The other drawback is that you may not want both of these zones to go on at once, even if you did have adequate pressure.
    It wouldn't be hard to remedy this. Just run an independent wire from your control box to each valve.
  4. dbinaz
    dbinaz New Member
    Apr 27, 2007
    it's actually for a drip system.
    I was just kind of leary if there would be enough current to fully open both valves? Or a strain on the timer?
    I may run another wire, but it's not going to be an easy run.
Similar Threads: Valves zone
Irrigation / Sprinkler Forum Possible top connect 2 valves in one zone? Jun 22, 2014
Irrigation / Sprinkler Forum Two Valves - One Zone - Power Short Jun 27, 2009
Irrigation / Sprinkler Forum Zones not working - Where are the valves? Sep 3, 2007
Irrigation / Sprinkler Forum Freeze Tolerant ball valves Feb 18, 2014
Irrigation / Sprinkler Forum automatic sprinkler valves May 1, 2013
