I'm neither a plumbing pro nor an inspector, but IMHO, it should work. If you can get to the second level tech support, you could ask the manufacturer, but the general, help desk person probably wouldn't know or be able to tell you as they typically only know the more common answers. You could do what you want with one centrally located valve and a multiport diverter, but then you'd have to agree on the temperature if both main showers were being used at the same time. By only using one valve, you'd possibly be able to upgrade to a thermostatically controlled valve, which, I prefer, for about the same costs. That's nice since as you use up all of the hot water, it will continually be trying to adjust to keep the outlet temp the same...nice if you're the second person taking a shower (or third, etc.). Certainly won't make hot water, but can keep things constant as long as there is some.
