2 shower heads
Discussion in 'Shower & Bathtub Forum & Blog' started by phil, Apr 13, 2005.
  1. phil
    phil New Member
    Apr 13, 2005
    First time poster with a question on a masterbath remodel. I am about to proceed with some plumbing for 2 shower heads on different walls. The bathroom is gutted to the studs and I will be using a 60 x 32 inch acrylic shower base. The existing water supply is 1/2 inch. I understand that you can do this using a diverter valve and basically have one set of controls. However, I was also told that you could have a valve (pressure balanced only) and a single set of handles for each head. I am not interested in running both heads`at the same time but I am wondering if this is possible and if so what are some of the implications. Thanking all replies`in advance.
  2. hj
    heads
    You can do it either way. If you use one control for both, assuming you use a diverter valve that is not strictly an "either one or the other" unit, you have to be sure the valve will supply enough water to feed both heads adequately.
Similar Threads: shower heads
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Two shower heads Dec 17, 2014
Shower & Bathtub Forum & Blog Sagging Shower Heads May 16, 2014
Shower & Bathtub Forum & Blog 8 shower heads on septic looking for grey water diverter Jan 15, 2014
Shower & Bathtub Forum & Blog How to increase water pressure/flow in showerheads Feb 9, 2013
