2 questions
Discussion in 'Tankless Water Heater Forum' started by pman, Mar 23, 2008.
  1. pman
    pman New Member
    Sep 27, 2004
    1. im gutting my house. should i use copper or pex tubing for the water lines? pros and cons of both plx
    2. im going with tankless water system. would you use motion detectors in various bath rooms to make hot water more readily available?
    tks much
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Where do you live?
    Is it an area where copper has longevity problems?
    How far are the bathrooms from the water heater?
  4. pman
    pman New Member
    Sep 27, 2004
    reply
    1. live in nj
    2. all bath rooms almost directly above water heaters. 2 would be two stories up. and one three stories up (3rd floor)...
    tks
  5. jadnashua
    There are people that love their tankless systems. Personally, where I live, I think they are just not a great solution. The winters in NJ are likely to be marginal for the use of a tankless...incoming watre will be fairly cold. Sizing one for multiple fixture use requires a very significant fuel supply, and upfront cost. I don't think you'd ever recover the upfront costs verses any fuel savings (which may not be huge depending on the system chosen. Personally, standby losses aren't as large as some would make you think they are in most cases.
    Pex would be easier to install. If done properly, it should work as well as copper...each has it's pros and cons.
    Use the search function...lots of discussions on pex verses copper.
Similar Threads: questions
Tankless Water Heater Forum Tankless install questions... Sep 29, 2014
Tankless Water Heater Forum Electric Tankless questions Jun 24, 2012
Tankless Water Heater Forum Newbe supplemental tankless questions... Oct 1, 2011
Tankless Water Heater Forum Recirculation pump questions -- Please help Nov 2, 2010
Tankless Water Heater Forum Navien Tankless Water Heater Comments and questions Dec 28, 2008
