2 questions about softeners
Discussion in 'Water Softener Forum, Questions and Answers' started by Fabricator, Apr 22, 2012.
  1. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The above is copied from Aquatel's web site and saves me a lot of typing so.....2 people x 75 gallons per day x 39gpg and no iron? comes out to 5858 gpg daily which could be done with a 48,000 grain capacity unit but.... I would go with a 64,000 grain capacity and get better salt efficiency. The 75 gallons per day is maybe high, most are using 60 gallons but either way I would still run a 2cu/ft filter
    That is what I said in that post. Everything above that is copied off Aquatell's web site (note the red words above and in my original post and as usual.......you come to the table with NOTHING and your comment to my post was just more of your constant inability to read and comprehend. Either buy a decent pair of glasses or take an adult ed class in reading comprehension or as you love to accuse us all of.....lay off the adult beverages LOL
  2. F6Hawk
    F6Hawk New Member
    Mar 20, 2012
    Flyer
    Alaska
    And those errors are?
    And I will stick to managing properties, thanks. As well as being able to treat other humans with the respect they deserve, without the constant needling that some are so good at.
  3. Gary Slusser
    Retired
    You are the one that copied/pasted it and didn't say so until way at the bottom of your post, and you didn't provide a link to what you were copying. And still haven't as if everyone else knows Aquatell.
    So in my opinion, you are responsible for any errors in your post, including what you copied from somewhere else.
    And I said and still say, if you knew how to do this stuff you wouldn't be posting the errors in the post.
    Here is what I'm talking about that y'all seem to not be able to find. Errors are in bold. Correct lbs for the K of capacity mentioned are in red.
    Unfortunately the resellers of the 24,000 grain system fail to reveal that it takes 27 pounds of salt to fully regenerate this system to the 24,000 grain level. It takes 11.25 lbs A more accurate description of the "24,000" system is "0.75 cubic feet". This is the amount of resin this system contains. While it's true that a user can get 24,000 grains of capacity from this amount of resin, it uses a massive amount of salt to accomplish this.
    What most dealers call a "32,000" grain system is more accurately described as a "1 cubic foot" system because it contains one cubic foot of softening resin. In order to get 32,000 grains capacity from this system the user would have to use 36 pounds of salt per regeneration! It takes 17 lbs if you can get more than 30K and 15 lbs for 30K.
    So it's more than missing zero typos you posted, you posted totally incorrect salt dose information. And how you made those typos when you typed a comma in the number (I.E. 4,800 and 6,400 for 48,000 and 64,000) says you dropped a zero but also had a comma in the wrong place and that you're copying/pasting pretending to know what you're doing but don't know.
  4. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    Making direct reference to a source of literature, data, facts, ideas or philosophies of another and obviously not claiming as one's own is being responsible. Not doing so is plagiarism. I see no plagiarism here. It's accuracy can be left to debate, of course. But debate, in a mature, respect arena are welcomed by most who are sincere and professional. No one really appreciates an adolescent approach to open discussions fro very long.
  5. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    ok, fella's. i am chewing on all this. a few more questions. my main is 3/4" . do i need the 7000sxt larger valve for this ? the extra $60 for it is fine, if it is going to help me. but seeing as how i am probably going to be unemployed very soon, it would be wise to save money when possible.
    bypass valves. i am sure the stainless is better, and it comes free with the 5600. plastic with the 7000. but is the plastic ok ?
    are there any options i should get, or just the basic model ?
    this is the place i am looking at, as is it out of my state = no tax.
    http://www.qualitywatertreatment.com
    as for my water usage, idk. but i do have a meter on it, and i just wrote down the # add will keep track of it.
    i have a floor drain right by the meter. but i need to test it to see if it can be used for the waist water. i am going to dump 2 5gl buckets down it to see what happens.
    i hope the pics show. first time i have ever seen em attached like this.
  6. Tom Sawyer
    Nov 29, 2010
    Maine
    You can side by side compare valves and make your decision based on features, price and versatility. Any of the fleck line will perform very well for you. I am selling more Fleck 7000's lately because I like the overall versatility of the valve and it's increased flow rate. The plastic bypass is fine as long as you dont "stress" it with the pipe connections.
  7. F6Hawk
    F6Hawk New Member
    Mar 20, 2012
    Flyer
    Alaska
  8. ditttohead
    Jan 9, 2012
    Ontario California
    Thanks. While I only do a few installs here and there, and I am a hard plumbing fan, the Falcon Flex connectors are excellent quality and I use them on some installs. I always use them on the large jobs to meet the warranty requirements, especially on the expensive systems. The plastic bypass is a better bypass than the stainless for flow reaons, and the versatility of the available plumbing connections. The stainless bypass is very nice as well. I sell a nearly equal amount of both and have basically no problems with either. If stress is put on the bypass, it will also be put on the valve, neither idea is good. So with either the plastic or the SS, you need to keep the stress off as you would any plumbing component.
  9. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
  10. ditttohead
    Jan 9, 2012
    Ontario California
    3/4" copper, the 7000 has a 3/4" copper sweat connectors available, albeit expensive. Order those, otherwise, if you are going to do a flex connection install, order the falcon flex 3/4" connectors and the 7000 has plastic 3/4" MIP connectors available. You may also want to order the 90 degree adapters for thew 7000 to make the installation alittle easier.
    The 7000 only has a 1-1/4" high flow bypass available.
    Round brine tank always. Square works, but for the long term, round is a superior shape for any container. Square brine tanks are always trying to change to round. Square brine tanks are used for space limited installs.
    Now before someone... chimes in on the round vs, square debate, please complete a physics course first, then well talk. And yes, I know square brine tanks are ok.... the question was raised, so I answered it.
  11. Tom Sawyer
    Nov 29, 2010
    Maine
    I don't like the square ones. Salt and dirt tend to load up in the corners.
  12. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    ok. i just ordered the 7000. i will report back when i get it.
  13. gojoe3
    gojoe3 Member
    Mar 27, 2007
    The hard part is now done
    outcast,
    I'll be ordering and installing mine also.
    I'm still trying to decide on the size.
    I'll start a new thread to ask some of the pros here some questions.
    Where did you end up purchasing the unit from?
    Earlier in this thread I think you mentioned quality water treatment .com.
    They are on my small list of online dealers I may purchase from.
    I liked that they included the gravel base, an upper distributor basket, and choice of bypass for no additional cost. They were also willing to ship it without the standard resin, so that I could purchase SST-60 on my own if I decided to go that route.
    Best wishes for a clean, no problem, install.
    You probably know this already...but, don't forget to get directions on the proper settings for the control valve in respect to your salt settings which will be dependent on the BFLC your control comes with. They may not be setup correctly when you get the unit.
  14. Tom Sawyer
    Nov 29, 2010
    Maine
    I have heard good things about quality water treatment.
  15. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    i ended up getting it for ohiopurewater.com, $630. but idk if i have these things = gravel base, an upper distributor basket.
    i now have it, it comes in 4 boxs. you can see them in the 2nd pic. this thing is a good bit larger than i thought it would be = but not a problem. the plastic bypass, this thing seem substantial . its plastic, but does not feel cheap.
    now, some questions. assembly instructions pretty much do not exist, at least not in the package. so i will have to look online. but i will ask here.
    1. the long tube in the brine tank. that just pushes up into the control head ? seems thats all it does.
    2. on the bottom end of this tub, there is a , umm, idk what to call it. but there is 2 in the package. what is the other for ?
    3, in pic 1, see the white fitting on the side of the salt tank, there is one on the control head. but there is no hose to connect them.
    4. the in/out fittings. will HD etc have adaptor fitting to fit ?
    5. the float, it fits. but says i may need to trim it. trim it for what ?
    thanx
  16. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    i'm a dope. i overlooked that they had email me a installation guide. and it looks good, so far.
  17. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    ok. i didn't thoroughly read the instructions. i don't see where it says how much salt, or what kind, i should get.
  18. ditttohead
    Jan 9, 2012
    Ontario California
    Pellet or solar salt are preferred, rock will also work, but it can be dirtier depending on the region and source. Home Depot, Lowes, etc all carry "water softener salt". Simply fill the tank, approximately 300 pounds will do. If the salt seems dirty, use it, but try a different brand next time. All salt is dirty, it is just a matter of how dirty.
    Congrats!
  19. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    around here, everybody carries salt.
    rock salt, are you talking about the stuff they spread on the roads ? i will look for the other stuff. 8 bags of it :eek:
    i hope my house doesn't tilt over :D
    on a side note. both of my neighbors don't even have a softener.
  20. gojoe3
    gojoe3 Member
    Mar 27, 2007
    Outcast,
    Congrats!
    You'll do fine. Just review the instructions a few times to get to understand them.
    I'm not a professional installer, but I have assisted on a few projects. From what I've learned ...
    there is a lot to do before even getting to the point of putting any salt in the brine tank. It's actually one of the last things you'll do. After everything else is done, including the programming, then you will add water, it should be put in the brine tank prior to adding salt for the first time. Fill to a minimum of 2" above the salt grid. Make sure that the salt dosage is programmed as recommended. After the first regen, the valve will automatically put the correct quantity of water in the brine tank. Then you'll do a manual regen , etc., etc.. (the manual should explain it all)
    Will you be doing all the plumbing work? Or will you be hiring a professional?
    Solar salt is my preference. I would advise against filling the brine tank with salt. There is no reason to fill it, unless you are going away for an extended period of time and you are the only one that maintains your new softener. Many people prefer to keep just enough salt in it to satisfy 2 or 3 regens. If you fill it, especially before you've confirmed that your system is working properly, and there is a problem with your brine tank, you'll have a lot of fun emptying the salt from it.
    Enjoy your new softener.
Similar Threads: questions softeners
Water Softener Forum, Questions and Answers Some General Softener Questions Jan 17, 2017
Water Softener Forum, Questions and Answers Katalox-Light or Filox Regeneration with an Oxidant Questions Nov 16, 2016
Water Softener Forum, Questions and Answers Cullingan medalist questions Aug 3, 2016
Water Softener Forum, Questions and Answers Installation questions for Fleck 7000sxt Aug 1, 2016
Water Softener Forum, Questions and Answers Just general Softener Questions Apr 24, 2016
