2 pressure tanks??
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rick.a, Jan 11, 2007.
  1. rick.a
    rick.a New Member
    Jan 11, 2007
    Palmer, Massachusetts
    Is it common or even OK to have one tank on the jetpump of a shallow well and another in the house, 150 feet away and about 20 vertical feet higher? I just bought a cottage with this setup. Switch is on the pump with the small tank. Much larger tank is in house with no switch or gauge.
    thanks,
    Rick
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I don't see where it could be a problem. It will just keep the pump from running so much. That's a good thing.
    bob...
  4. rick.a
    rick.a New Member
    Jan 11, 2007
    Since this is a seasonal cottage and must be winterized each fall, Can I get rid of the tank at the pump and move the switch to the house tank? This is to simplify the draining or pump removal in the fall.
    Rick
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You sure can.
    bob...
  6. rick.a
    rick.a New Member
    Jan 11, 2007
    thanks Bob.
Similar Threads: pressure tanks
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Amtrol Multi-Dome feature of Well-x-trol and Champion pressure tanks May 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well water, pressure tanks and filter issues May 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. installed new pressure switch, low pressure seems like tanks are not filling Dec 11, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Problems with Wellmate SP-series pressure tanks? Jan 3, 2013
