2 Piece Gwenyth vs 1 Piece
Discussion in 'Toilet Forum discussions' started by tesla, Sep 12, 2009.
  1. tesla
    tesla New Member
    Sep 12, 2009
    DFW (Garland), TX
    Prefer 1 piece but a couple of things are holding me back....price and Map rating. Terry states that anything over 500 Map is overkill but the 1 piece is rated at 500 which is at the minimum recommendation. The 2 piece is rated at 800 which to me means that it will never clog unless some foreign object is put down there. Also, some have mentioned that one advantage of the 1 piece is that there will never be a leak between the tank and the bowl. Are leaks a concern or problem with 2 piece Toto's? Regarding the 1.28 gpf, some have mentioned a smaller water spot. What is the concern with that? Is it correct to assume that the water spot enlarges if you convert this to 1.6 gpf? Finally, I currently have 3 Universal Rundle toilets manufactured in 1994 that clog fairly often. What kind of improvement can I expect?
    Thanks for any help.
    Barry
  2. Terry
    Aug 17, 2004
    Either one will work better then what you have.
    I've been using the 1-piece Gwyneth for a year.
    It's now called the Ultramax II
    Water spot between 1.28 and 1.6 is the same now.
    [​IMG]
    TOTO Gwyneth MS604114CEFG Made in USA
    Video of performance
  4. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I agree with Terry. I bought 2 Gwyneths (one-piece) based on his advice that differences between MaP scores are irrelevant, as long as the scores are 500 or higher. Have had no trouble with these toilets. I really like the sleek look of the one-piece models.
    Here's a look at one of mine, from a different perspective.
Similar Threads: Piece Gwenyth
Toilet Forum discussions User review on CST454CEFG 2 piece TOTO Drake II, Gwenyth, Owner comments and pictures Jan 26, 2009
Toilet Forum discussions No SanaGloss "sticker" on 2 piece Gwenyth Jan 24, 2009
Toilet Forum discussions Kohler Tresham® K-3981 Comfort Height® skirted one-piece Dec 23, 2016
Toilet Forum discussions TOTO Ultramax One Piece Elongated ADA Toilet slow leak Oct 29, 2016
Toilet Forum discussions Toilet bowl is tilting over half an inch due to small wood pieces placed under Oct 26, 2016
