2"main stack vent, big enough??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rheagle1, Mar 20, 2005.
  1. rheagle1
    rheagle1 New Member
    Mar 10, 2005
    Currently we have a 4"cast iron main stack/drain pipe. We are putting in a new bathroom, and going to be taking out the old main vent. We are wanting to just use a 2" main vent in the wall since the current walls are only 2x4. All that would be going off this vent would be the toilet, sink, and tub then going to the sewer line. We will be tapping back into this 4" pipe in the attic. Eventually we will be redoing the kitchen and it will have it's own 2" vent going to the sewer and attic. Will this work, or cause problems. Thanks much.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    depends on where you live
    I am down with the flu today so I have ben posting on here like a mad man.
    Better than just sitting in bed.
    In indiana, all you need is one 1 1/2 vent going out of the roof to do the whole home....even a 3 -5 bathroom home!!
    they claim its all just air, and the system works the same wether its 1/1/2 or 3 inch
    Its good to have a couple of vents out the roof if it can be done, but its not really necessary
    just call a local plumber and get a free estimate.
  4. Terry
    Aug 17, 2004
    If this were in UPC plumbing code country, you would need a composite 4" venting the home, that could be done by combining four 2" vents.
    You will notice that many homes have several pipes, (vents) on the roof.
    Working with a 3" waste line out of the home, you will often see two 2" vents and one 1.5" vent.
    Will the plumbing work with the 2" vent? Yes.
    When I'm plumbing, I count up the vents leaving the roof, the inpector will too. Ask the inspector first, what he will allow before committing too much time to this.
    If I plumb, I do it to the code book, then I don't have to worry. It's much quicker to do it right, then it is to try to convince someone against it.
    Tub 2.0 fixture units
    Lav, 1.0 fixture units
    Toilet, 3.0 fixture units
    Total, 6.0 fixture units
    A 2" pipe will handle 24 fixture units, that's like four bathroom groups.
    When I'm plumbing condo's and apartments, I may have eight or ten four-story groups that look somewhat like this but taller.
    http://www.iapmo.org/common/ROP2004/upc04rop/preprint/ch7.pdf
    [​IMG]
  5. rheagle1
    rheagle1 New Member
    Mar 10, 2005
    Thanks! I think we'll end up doing the 3" vent. From the calls I made sounds like that's the code. Guess I better do it then :D
Similar Threads: 2main stack
Plumbing Forum, Professional & DIY Advice How to fix condensate line draining to vent stack? Thursday at 7:06 PM
Plumbing Forum, Professional & DIY Advice Drain design with stack in middle of 2 sinks + washer Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Main Stack as vent for tub and shower drain Mar 8, 2017
Plumbing Forum, Professional & DIY Advice Toilet offset from stack question Mar 1, 2017
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Feb 22, 2017
