Mass_ tech89
Hey everyone
I have a problem with a two line jet pump that is not building pressure. I must admit I am not the most skilled with wells.
The first time I was called out the pump was continuously running. I checked the charge on the pressure tank which I found to be low. After filling it back up the pump ran but could only pump to a max of 38 psi. Not being sure what the issue was I replaced the pressure switch and the tubing as the contacts were worn badly. However the pump still would not pressurize above 38 psi so I adjusted down the cut off pressure so the pump would turn off. I don't know what was causing the reduced capacity but it was 9 at night so the homeowner was happy with it and I left.
5 days later I get the call pump Is not running at all. Pump was getting 240v but the pressure switch was not engaging. If I manually closed the pressure switch the pump would kick on and eventually the p switch contacts would close on there own and pump would fill the pressure tank to about 35 psi. Pump was drawing 6 amps pretty close to the nameplate. I also noticed that now the pump was dripping from the volute. My theory is homeowner shut off discharge line ball valve blowing the seal and thus the leak.
I told them that they needed a new pump it's very old and my thoughts were its pulling in air from the leak reducing it's capacity. Do you think think this a solid diagnosis? I really am curious to what could have been the original problem before the very obvious water on floor.
this pump is for a deep well and had some kind of pressure controlling valve that the tubing for the pressure switch connects with. Does anyone of any experience with how to test one of these valves to ensure its letting the pressure switch close
Another question about these systems:
If I suspect a leak on the suction side can I pressurize suction line to see if it holds pressure
Artached is the picture of the valve I'd like to know how to troubleshoot and what it does exactly
Any input great appreciated
Thanks guys,
N
The pump is a jlo7n.
Thanks guys,
N
