2 lights on same circuit controlled by 2 switches
Discussion in 'Electrical Forum discussion & Blog' started by lynams, Oct 20, 2012.
  1. lynams
    lynams New Member
    Oct 20, 2012
    Texas
    I have a 3 switch plate on my wall. One switch is for an indoor light switch ( 3 wire, as there are 2 on the same line). The other 2 switches are two separate outdoor light fixtures. I am replacing 2 outdoor (motion sensor) light fixtures that are controlled by 2 switches. Originally, the two lights were connected together by a very thin, 3-connector(?) flat cable which is also being replaced. The first light when replaced by itself worked, but when I turned both switches on it now stops working. I am still trying to get the first one (closer to the switch) to work.
    The old flat cable did not have colored wires, didnot help me with how the two lights were connected, except the middle wire was wired around the cable itself, or not used.
    How do I make sure I have them connected right and both to operate?
    THANKS.
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    You look at the installation instructions that came with the fixtures!
  4. jadnashua
    Thin flat wires are not typical for line voltage. WIthout being there, it's hard to say if the original installation was correct.
    Basically, if one light works, you'd parallel the wires (black/white/ground or hot/neutral/ground) from one to the other. Thin, flat wires may be low-voltage control cable from the remote sensor to the light fixture, not power.
    Hard to say without being there.
  5. hj
    From your description, we do not know if those are even "3 way switches", or how you are wiring the lights and switches together. WE would need a lot more information to even try to diagnoes the problem.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Is this three switches in one box or what?
    Three wire? Is this one black one white and one bare and two what on the same line and what is the line?
    If the two lights were on two different switches why would the very thin three conductor be doing between these two fixtures that are on two different switches?
    If it worked why are you still trying to get it to work?
    Again why were these two connected together if they were on two different switches?
    Maybe if you could post pictures of the switches we could help but your post doesn’t make any sense.
    Your welcome
Similar Threads: lights same
Electrical Forum discussion & Blog Can 2 lights (same circuit), 2 switched, be converted into one switch? Oct 2, 2010
Electrical Forum discussion & Blog Residential Lights and Outlets on Same Circuit? Aug 23, 2010
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
