2 Expansion Tanks
Discussion in 'Water Heater Forum, Tanks' started by TimAllen47, Feb 12, 2012.
  1. TimAllen47
    TimAllen47 New Member
    Feb 12, 2012
    North Carolina
    I discovered that I have two water heater expansion tanks, one off the water heater and one under the floor in the crawl space. Do I need to have two expansion tanks? I do have low water pressure could this a be a possible reason why my presurre is low in the house. I only have one water tank in the garage.
  2. Terry
    Aug 17, 2004
    You only need one expansion tank, but having one doesn't lower pressure.
    Having two is fine.
  4. jadnashua
    Do you have a boiler for heat? That second expansion tank may be for the boiler, not on the potable water system. While they look the same, you shouldn't use one for the other - i.e., not all are rated for potable water use.
Similar Threads: Expansion Tanks
Water Heater Forum, Tanks two water heaters, two expansion tanks Tuesday at 10:40 AM
Water Heater Forum, Tanks Thermal Expansion Tanks Sep 24, 2013
Water Heater Forum, Tanks 2 Gallon Expansion Tanks...Hot water VS Well expansion tank Oct 12, 2012
Water Heater Forum, Tanks Leaky Valve and Thermal Expansion Tanks Mar 2, 2011
Water Heater Forum, Tanks Expansion Tanks: where/how do they fail? Feb 12, 2009
