2" drain for bath lavs
Rmelo99
Network Engineer
When I did the drain lines for my 2nd floor bath sinks I used 2" pvc. I also used 2" tees. Now that I'm getting ready to connect the sinks I have to figure out the best approach since bath lavs use 1.25" drains
Do they make a 2" to 1.25" trap adapter so I can go right into the tee with the trap and not use a bushing?
Should I use a 1.5" trap and then just go down to 1.25" at the trap to sink tailpiece?
Thanks
Rem
Joe the Plumber
Pluumbing, of course
For two lavs you need 2" until you separate them.
Trap arms are 1-1/2"
You can use a 1-1/2" trap with the 1-1/2" x 1-1/4" reducer at the tail piece of the lav drain assembly.
Rmelo99
Network Engineer
thanks, unfortunatley i used 2" for my trap arms. :-(
I think I will use a 2"-1.5" flat bushing and the use a 1.5" trap. Then I will resize to 1.25" at the tailpiece.
