(2) 4x12 Solar hot water panels...now what to do with them
Discussion in 'Solar and Geothermal Water Heating Forum' started by Scuba_Dave, Dec 8, 2009.
  1. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Picked up 2 free 4'x12' solar hot water panels off Craigslist for Free
    They seem to be in pretty good shape
    The Recirc water heater tank failed, panels are good
    Only Mom (older) at the house so Son wanted the panels gone
    I'm debating on how to use them
    Glycol w/recirc tank would cost $$....not sure how much, over $800 ?
    Plus the controls etc
    Pipes are Alum, thought of using them to heat the pool
    But not sure if the chlorine would damage the pipes ?
    ---the "white" rust...?
    Another option would be to use (1) to heat my hot tub in the summer
    2nd one to heat water going to the water heater
    Another thought was to use glycol & connect these to some extra radiators to help heat the house
    But then what do I use it for in the summer ?
    Drain the glycol...and use for hot tub & direct to HW heater ?
    Ideas....thoughts ?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Whatever you use them for, don't run 'em open loop (to either a hot tub or a pool) or you'll wreck the aluminum.
    Stagnation temps can be quite high- design the system with safety in mind or you risk taking a 200F+ glycol shower if a pump should fail to kick on or some obstruction develops, or you underdesigned the heat exchange/storage on the extraction end.
    Low temp pre-heat for domestic hot water is pretty easy to hack with surplus panels and you have plenty of panel area to do it. Check out some of the DIY stuff they get into at builditsolar.com. See: http://www.builditsolar.com/Experimental/PEXColDHW/Overview.htm You could probably keep staganation temps under control by mounting them more steeply than recommended for max-annual gain, and use PEX heat exchangers in a high mass tank (rather than open loop drainback the way Gary Reysa did his homebuilt) for both the DHW and glycol loop. By running it with low temp high-mass storage, as preheat to your hot water heater you get a HUGE solar fraction, and very high efficiency on the panels. You'll need to read up on how to properly set up purge, charge & pressurize the glycol loop, but there's little rocket science involved.
  4. Alphacarina
    Alphacarina New Member
    Sep 5, 2009
    Biloxi, MS
    I would use them for domestic hot water as well - That's going to be the biggest bang for your buck . . . . typically a quater to a third of all your home energy use
    Buy a 10 gallon drainback tank and hook the panels to it and the tank to your existing water heater. Probably cost you around $2500 to do a first class job of it and likely Uncle Sam will reimburse you for half of that or more - If so, you'll have a very short payback of just 2 or 3 years
    Don
Similar Threads: 4x12 Solar
Solar and Geothermal Water Heating Forum Replacing Solar Storage Tank Jan 10, 2017
Solar and Geothermal Water Heating Forum How to disable my batch solar hot water heater temporarily Dec 8, 2016
Solar and Geothermal Water Heating Forum Plumbing Water Heater Into Solar Loop Sep 24, 2016
Solar and Geothermal Water Heating Forum Solar water heating optimization Jun 5, 2016
Solar and Geothermal Water Heating Forum Solar Assist For A New Boiler May 5, 2016
