2-12gauge and a 14 gauge for ground?
Discussion in 'Electrical Forum discussion & Blog' started by trackerxx, Mar 3, 2008.
  1. trackerxx
    trackerxx New Member
    Feb 27, 2008
    Is it okay for me to use two 12 gauge (for hot and neutral) and one 14 gauge wire for ground? I think 14 gauge is easier to work with but I don't want to violate code.
    I'm installing a dedicated circuit running EMT for a gas dryer.
    Thanks.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Wouldn't the EMT be the ground?
    If you install a wire for the equipment grounding conductor it MUST be a #12
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    No can do.
    Jason
  5. MarkHash
    MarkHash New Member
    Mar 13, 2007
    Wisconsin
    I am sure it's against the code, but it would definitely carry the fault current long enough to pop the breaker, which is what it is there for. I'm sure there are deep reasons for like sized ground wires but it escapes me right now. Probably to make sure the circuit breaker operates properly in much larger applications.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't know code, but I would use 12/3 color coded for 220VAC. (Red, Black, and Green) Of course electricity doesn't care what color the wire is, but if it had to be worked on in the future, it might help.
  7. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    For a GAS dryer?
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    And I thought the 12 was a bit much... :D:D:D:D (I know its required....)
  9. Lakee911
    Aug 23, 2005
    Columbus, OH
    12/3 is ROMEX® and it contains a white, black, red and a bare ground. It's 4W, which most new dryers should be. For a 220VAC dryer this COULD be used, but generally they're at least 30A so a 10/3 would be used for the increased amperage. He also said that he's running EMT, so ROMEX® probably isn't the right choice. Lastly, a gas dryer is probably 120VAC.
  10. Lakee911
    Aug 23, 2005
    Columbus, OH
    Actually, I was thinking that he could supply a 15A breaker and then get away with it, but the more that I think about it, if you increase the current carrying conductor (say for voltage drop, for example), I'm pretty sure the ground needs increased too. The EMT could be used if its continous and contains any appropriate bonding jumpers.
  11. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    210.11(C)(2) requires a 20 amp laundry circuit.
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    THAT was my point!
Similar Threads: 2-12gauge gauge
Electrical Forum discussion & Blog What wire gauge should I use Dec 30, 2015
Electrical Forum discussion & Blog 12v: will a short section of 16 gauge cause problems? Sep 22, 2014
Electrical Forum discussion & Blog Wire gauge for under cabinet lighting. May 3, 2014
Electrical Forum discussion & Blog 16 Gauge Wire in Circuit? May 14, 2013
Electrical Forum discussion & Blog Please Explain Small Gauges of Extension Cords Nov 7, 2012
