2 1/2" ABS as underground conduit, Plumbers, HELP!
Discussion in 'Electrical Forum discussion & Blog' started by Homeownerinburb, Sep 5, 2012.
  1. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    Guys,
    I am looking at needing to cut and add a sweep to some underground conduit, as the arrangement of the service has changed.
    This was installed 40-50 years ago. The crud is down 5' in a hole and is tough to get at.
    What sucks: it looks like 2 1/2" abs. It certainly is All Black Stuff. But no such size exists.
    It really is down pretty far. Any deeper and I could drop a casket in there. So I am having difficulty working out exactly what it is.
    So I wonder, is it in any practical way possible to join ABS to grey pvc? That I can get in 2 1/2", including a sweep.
    I wonder if I need to just use a rubber coupling?
    Or have I got it all wrong, and the stuff is actually 2"? I would not put it past the local utility...
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Not sure but that sounds like it could be a Gas line.
    I would check it before I started cutting.
  4. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    No, no. The gas comes in quite elsewhere.
    The general had a utility spotter mark things.
    Got it worked thru today. Believe it or not: two #2 and one #4 aluminum, in 1 1/2" abs.
    And we are replacing the 100 panel with a 200 amp panel. It has been approved. I don't get it.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    the answer lies in the utility rules not the NEC.
  6. hj
    THere should be a lot of difference in the "looks" between 2 1/2" and 1 1/2" conduit.
  7. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Hi Don. Eating too many bean burritos makes everything sound like a gas problem:cool:
  8. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Yeah, it was 5' down in a pit. Hard as hell to work on in any way.
Similar Threads: underground conduit
Electrical Forum discussion & Blog Conduit Underground from House to Garage (+water) Sep 29, 2016
Electrical Forum discussion & Blog Underground conduit and pull-box questions Oct 2, 2011
Electrical Forum discussion & Blog Underground conduit Mar 27, 2010
Electrical Forum discussion & Blog Can THW wire be used underground in conduit? Nov 25, 2009
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Wednesday at 7:29 PM
