1989 Kohler San Miguel flush valve replacement question . . .
sjh
California
This model takes the valve with the "twist lock" and not with the (3) lugs which can be tightened slowly compressing the washer in the process. Suggestions as to what I can lubricate the compression washer with that will make assembly easier but not deteriorate the washer material?
I know nothing about that valve, but silicone grease is what you put on rubber to lubricate for a longer period. Do not use a petroleum-based grease.
Another alternative, since it only has to lube for a bit, is liquid soap.
Get a small container of plumber's silicon grease. It will last you a long time. It makes lots of things easier.
