1980 house with black stuff around the bathtub drain. I'm putting in a new tub
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SinnerDC2, Jan 1, 2012.
  1. SinnerDC2
    SinnerDC2 DIY infant
    Jan 1, 2012
    Louisiana
    [​IMG]
    I'm putting in a new tub and over course nothing fits. The problem is the drain centered, but its to low and the overflow is short and needs to move forward. I cleaned the area around the drain and it looks like black glass or epoxy, but from searching the forum I think it might be lead. The house was build in 1980 so it seems a little young for lead.
    Here are the drain pics. This if my first venture into non-faucet plumbing.
    [​IMG]
    [​IMG]
    link to bigger pictures
    https://picasaweb.google.com/tullostech/GuestBath?authuser=0&authkey=Gv1sRgCI3KmO_r-bDKrAE&feat=directlink
    It doesnt look very simple to replace the drain. Can I just raise the lower drain with some type of adapter? and raise overflow?
    Thanks
    Nick
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Unless you are replacing a tub with an identical one, you should always plan to replace the drain and overflow assembly and sometimes the drain line will need to be moved. In an 80's house, I would not expect to find any lead joints.
    You are going to need to dig out the joint below that drain shoe and determine what the joint is. Unless it is in concrete, it shouldn't be too tough to make right.
  4. SinnerDC2
    Jan 1, 2012
    Louisiana
    I agree, the pics are super small. I enlarged them.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Yes, I edited my post after seeing the linked pictures.
  6. SinnerDC2
    Jan 1, 2012
    Louisiana
    ok, i figured the black stuff was lead. I got if off another thead.
    what is the black stuff?
    [​IMG]
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Good question. Looks like someone had some extra roofing mastic they needed to get rid of. Someone's idea of waterproofing maybe?
  8. SinnerDC2
    Jan 1, 2012
    Louisiana
  9. hj
    IF your old drain and overflow had fit the new tub, THAT would have been a miracle. You almost ALWAYS have to relocate them, but HOW to do it varies with EVERY installation. Most users would NOT want to reuse the old drain fitting anyway, even if it did fit. That is NOT lead, but I am not sure what it is. It appears to be too "hard" and shiny for roofing cement.
Similar Threads: 1980 house
Plumbing Forum, Professional & DIY Advice Kohler Cygnet faucet handle -1980's handle & assembly that needs to be replaced Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Need Help identifying Bathroom Faucet 1980's Aug 10, 2013
Plumbing Forum, Professional & DIY Advice Need help identifying Model Number of 1980's vintage Kohler bathroom faucet Feb 4, 2013
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Leak after 10 years in house Feb 7, 2017
