1980 Delta 600 Single Handle Shower Leak
Discussion in 'Shower & Bathtub Forum & Blog' started by Kharry, Oct 7, 2008.
  1. Kharry
    Kharry New Member
    Oct 7, 2008
    My shower handle has a leak. It's a Delta from 1980. The leak originates from the cartridge that houses the control ball. I think I found the part at my local HD (#46074). Can you tell me if this is indeed the right part for this old shower handle and how to install it?
    I've researched the issue and found out that there may be a "plumber's clip." Is that true? Or am I better off just changing out the ball and putting in new springs and seals? Thanks for any help you can offer!!
    [​IMG][/IMG]
  2. hj
    Delta
    Cap, ball, springs, and seats. BUT if the cap does not unscrew easily, and that one looks like it will not, DO NOT try to force it or you will be installing a new faucet because I will not be around to repair it for you.
  4. jadnashua
    As HJ mentions, getting the cap off is the problem. If it is corroded on and you apply too much torque, you'll bend the supply pipes and ruin the whole thing. You might try wrapping it in a paper towel, saturating it with vinegar, covering it with plastic wrap and letting it sit overnight. It might disolve some of the mineral deposits. If that doesn't work, some PBlaster is a good penetrating oil. If that doesn't work, a hack saw and some careful destruction should get the cap off without destroying the threads or the parts you aren't going to replace.
  5. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    After you dissolve some of the crud or PBlast it overnight, clean it up with windex, dry it, and use an old leather belt between the chrome and a channel lock pliers. The leather usually provides enough grip while protecting the chrome from damage. And remember, righty tight lefty loosie.
  6. hj
    Delta
    GRIP is not the problem because the cap has knurling for that. The problem is breaking the corrosion which has the cap sealed to the body. Heat is the only thing that will loosen it, and then install the new cap which is not supposed to lock up that way.
  7. Southern Man
    Jun 27, 2008
    North Carolina
    Chrome knurling scratches up nicely.
  8. Kharry
    Kharry New Member
    Oct 7, 2008
    Ok. A plumber came in and repaired the faucet. He replaced two seals and the springs and the leak disappeared. He also looked at the other shower and determined that it is not leaking. This work took about 1/2 hour. He charged me $175. Is this reasonable? I live in Atlanta.
  9. jadnashua
    You usually pay a premium for the first hour. He can't make any money traveling to and from your home. That's reasonable. If he had stayed an hour, it may have been the same, and subsequent hours probably less.
  10. hj
    Delta
    I always change the ball also, and sometimes the cap depending on its condition. No way to tell since we do not know the market conditions in your area. Here it would be about right for a flat rate company, and high for a time and material one. But, given the right conditions, the two situations could be reversed.
  11. Kharry
    Kharry New Member
    Oct 7, 2008
    Sorry. Yes, he changed the cap. He didn't change the ball because they don't malfunction in his experience.
  12. Cass
    Cass Plumber
    Nov 12, 2005
    The price seems OK to me...
Similar Threads: 1980 Delta
Shower & Bathtub Forum & Blog Delta Monitor - removing assembly rp19805 Jul 2, 2009
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
Shower & Bathtub Forum & Blog Need help identifying 1980s Roman tub faucet Oct 18, 2015
Shower & Bathtub Forum & Blog 1980 shower tap - how to repair leaking tap Jan 30, 2014
Shower & Bathtub Forum & Blog 1980s American Standard diverter issue Oct 13, 2013
