1960's Crane Bathroom Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbbluueyes, Mar 22, 2006.
  1. bbbluueyes
    bbbluueyes New Member
    Mar 22, 2006
    I am trying to replace the entire stem on both of the hot and cold water...
    1. Water is hooked up fine, if stems are off and water is turned on there is pressure
    2. When I put both of the stems in and turn the water on the shut off valve I get a trickle of water if I turn the top threaded piece.
    3. I have checked for interior rust, it appears fine. I am wondering if there is a special way to put in the stems...ie. if I am screwing them in too far...I tried adjusting this also, the so called length of putting them in.
    any suggestions would be great...thank you!
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I really can't under a thing you said, but if they are 1960s its probably a "Crane" "dial ease" faucet.
    The washers and stems are like no other faucet.
    Can you describe the stem and washer?
  4. bbbluueyes
    Mar 22, 2006
    yes, replacing both dial eze valves
    yes, I am replacing both of the dial eze valves....the entire bronzish piece that screws in from the top of the faucet.
    after replacing both dial ease and turn on the water from the supply below, I get no water out of the faucet.
    I am wondering if there is a trick to replacing the dial ease....
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Crane
    Make sure that you removed the old washer from the bonnet. In other words did you keep the old washer when you put in the new stem and washer and o-ring?
    Don't understand why you have low flow unless the aerator is plugged or there is an obstruction inside at the spout.
    I always liked that faucet and the way it repaired.
  6. hj
    dial-eze
    If you have water without the stem, and none with the stem in, then the problem is in the faucet, probably a plugged aerator. There is almost no way you could turn the stem on and not have water flow through it, especially to have it happen on both sides.
Similar Threads: 1960's Crane
Plumbing Forum, Professional & DIY Advice Sink drain rough-in... to 1960's era male threaded bronze? Aug 2, 2010
Plumbing Forum, Professional & DIY Advice Any tips for packing a vintage Crane Mixing Valve Jan 29, 2016
Plumbing Forum, Professional & DIY Advice 36 year old Crane Demming sub pump Oct 27, 2015
Plumbing Forum, Professional & DIY Advice Crane faucets from 1930 - desperate to repair.... Aug 25, 2013
Plumbing Forum, Professional & DIY Advice Angled Crane Dial-Ese faucet mount lavatory sink repair? Feb 20, 2012
