1956 Case Toilet /broken seat
Discussion in 'Toilet Forum discussions' started by mrwil, Jan 24, 2006.
  1. mrwil
    mrwil New Member
    Jan 24, 2006
    I have a Case toilet build in 1956. Recently the tolet seat cracked on one side. A few days ago the inevitable the other side snapped. I debating if I should replace the toilet seat providing I can find one, which probably won't be its oroginal color (a rose pink) or go to a new toilet. Any suggestions
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    First of all, is the toilet working properly? Second, how important is it to you that the seat be a matching rose color? Third, is this a seldom used toilet or one used everyday? Finally, is it important to you to just get by for now or do you want to do the job right and modernize the bathroom? It seems to me to pretty much a matter of your opinion on those questions to do a $20 fix or several hundred $$ for a new toilet. One could easily argue that a 50 year old toilet has lived its life and should be retired. I would warn you that 50 years ago toilets were installed differently than today so some plumbing on the drain will likely be required to install a new one. It's your call.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Call a good supply house and see if OLSONITE makes seats that will color match and fit the old Case. Be sure you have the year and silhouette. There was a post the other day that pictured all the old Case toilets and listed repair parts.
    Seems to me that there is no difference in setting the old Case other than it's hard to set because you can't see the closet bolts. It's a 12" rough and a regular closet flange. You should be able to set any toilet there, but I would opt to keep the old one. Put on a new seat and do a repair.
  5. plumbernj
    plumbernj In the Trades
    Aug 14, 2005
    New Jersey
Similar Threads: 1956 Case
Toilet Forum discussions 1956 Case Toilet /broken sink Jan 24, 2006
Toilet Forum discussions Case 3000 Jan 26, 2016
Toilet Forum discussions need advice on replacing case 3000 Nov 19, 2015
Toilet Forum discussions Case 3000 toilet Nov 18, 2015
Toilet Forum discussions Case 3000 Wall Hung Sep 2, 2015
