1950s Crane Tub/Shower Problem
Discussion in 'Shower & Bathtub Forum & Blog' started by deesworld, Jul 20, 2011.
  1. deesworld
    deesworld New Member
    Jul 20, 2011
    Baltimore, MD
    When using the shower, just as much water comes out of the tub spout as the shower head. The hot and cold knobs also need some attention because when you open the faucet more less water comes out (its a science to get the correct temp) Should I start with the tub spout since that's where you turn on the shower head? Is this where I will find the "diverter" you all are talking about in other posts? Been waiting for my husband "to get around to it" but he doesn't use this shower so I may be waiting a looong time (we've been here for 15 years already).
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Maybe you need to invite him to use it.
    If the tub spout has a pull up diverter built into it then yes, that would be a good place to start. If the diverter comes out from the wall, then leave the spout alone.
    As for the more is less faucets, do you have a brand and model or can you post a pic?
  4. jadnashua
    If the diverter to activate the shower is on the tub spout, the best one generally available is one of these http://www.deltafaucet.com/search/results.html?q=pull-down+diverter+tub+spout . As you can see, they come in numerous finishes and styles. I installed one at my mother's and it works fine. The only thing is that when you shut the water off, the spring that retracts the pull-down is moderately strong, and it clunks. After the first time, you'll ignore it.
Similar Threads: 1950s Crane
Shower & Bathtub Forum & Blog 1950s tub drain mechanism fell apart with age...how to repair Apr 7, 2013
Shower & Bathtub Forum & Blog Replacing 1950s tub fixture -- advice on selection and installation Mar 6, 2013
Shower & Bathtub Forum & Blog Help identify 3 handle tub fixture from 1950s? Dec 21, 2012
Shower & Bathtub Forum & Blog 1950s American Standard Shower Mixer Valve leaking Jun 13, 2012
Shower & Bathtub Forum & Blog Crane (OEM) tub tap - H & C tabs - keep popping off! Jan 1, 2012
