1950 home on slab, returns on floor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by karen1234, Oct 10, 2009.
  1. karen1234
    karen1234 New Member
    Oct 10, 2009
    illinois
    Our home was built in 1950. It is on a slab, and the returns are in the floor, run through concrete ducts. Where the returns come together under the furnace, there is an about 8" drop. While my husband was putting a new filter in, (under the furnace) he noticed that this area is filled with water, but only about an inch or two. He used a wetvac to suck the water out, and slowly but surely, the water returned. It does not reach the return ducts, and they are dry, however, in looking at this area below the furnace more closely, this has been happening for a while, because there is a line where the water has been and never rises above. I guess that explains why in the past when the furnace turns on it smells musty. This smell is bad today though. Any ideas?
  2. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Sounds like a low point in the system. Condensation is building up on all of the vertical runs or the duct work is pitched slightly so it all runs down to the bottom where the water is collecting. A small hole drilled where the water collects would drain the water out of the duct work, but you'd have to patch up all the holes and see if there are any other areas where water or condensation could occur.
    Check the humidity levels in your house since the lack of a proper vapour barrier may be causing too much humidity. Especially with the weather getting colder and wetter, this is a good time to fix it now. You may have to replace some ducting if it is rusted out as well.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I might worry about mold and airborne bacteria also. Is the bottom of the furnace all rusty?
  5. hj
    water
    There are many ways the water could get in there. If it always stays at a certain level it could be a high water table, or that could be the point where there is a hole so the water cannot get any higher. You could have leaking plumbing or soaked ground after a rain. Without checking the ductwork and other inspections there is no way to diagnose your situation.
Similar Threads: 1950 home
Plumbing Forum, Professional & DIY Advice Confirm lack of proper venting on 1950's home Sep 7, 2015
Plumbing Forum, Professional & DIY Advice 1950s home - copper type/diameter? Apr 6, 2006
Plumbing Forum, Professional & DIY Advice 1950 Renovation Questions Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Question about 1950's bathroom sink faucet Nov 14, 2016
