1949 Eljer? toilet in need of lift rods/tank ball - with pictures!
Discussion in 'Toilet Forum discussions' started by iaceit, Jan 24, 2014.
  1. iaceit
    iaceit New Member
    Jan 24, 2014
    bc
    Hello!
    Hoping to find some replacement parts (original replacements or new tank ball or flapper) for a 1949 toilet with no manufacture name (that I can find), but with a 36 imprinted in the tank and a June 1949 on the lid.
    The drawing with the red arrows shows the parts I need (even tho the other parts are a little different from mine - see pictures). The rod guide might be in the way if I don't remove it, if a new flapper is installed.
    Anyways, I am hoping someone has some ideas for me!
    Thanks
  2. Terry
    Aug 17, 2004
    American Standard used a tank ball and threaded brass rod like that at one time.
  4. iaceit
    iaceit New Member
    Jan 24, 2014
    bc
    After much searching I found out this is a Eljer Sylenta 5120.
    http://www.youtube.com/watch?v=l-lPXHlbbnQ
    Do you know of a new universal flapper that may work with this?
    Thanks for your response
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Good find! Actually, the guy on youtube must be a Terry Love devotee, as he says that he is now using the Korky quietfill exclusively -- exactly what I was going to recommend for your fill valve instead of a ballcock. And he has the right one (white cap) for the toilet involved, although he can probably save some water with the 528MP (silver cap) adjustable one as I imagine that the bowl is being overfilled upon refill.
    I'm thinking that you can't just drop a flapper on there, because the overflow around which you would hang it is actually a molded part of the tank. Easiest solution (and a perfectly good one) is just to replace the tank ball and leave everything else as-is. Did you want the part because the toilet is leaking around the tank ball? I dont see why you couldnt just get a similar generic tank ball like this and install it on your existing lift wire. http://www.lowes.com/pd_24454-143-P...l=1&currentURL=?Ntt=flapper&page=1&facetInfo=
    They also make them with the lift wire attached, too.
    http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
    I don't think it's a magic part, from what I can see anyway.
  6. hj
    You just need an upper and lower lift wire, which any good hardware store should have, and a tank ball.
  7. iaceit
    iaceit New Member
    Jan 24, 2014
    bc
    Alright, thanks for everyone's input. I have found some parts and will give it a go.
  8. achutch
    achutch Member
    Oct 20, 2005
    Vermont
    Eljer Sylenta
    It's great to see one of my videos on this forum. After cleaning as much of the staining as I could inside the tank and making sure the china flush valve seat was clean, I installed a regular tank ball and lower lift wire, and an authentic Eljer handle (any generic will do, but I like my restorations to be exact). Any tank I rebuild gets the Korky Quietfill regardless of brand or vintage. They are easiest for me to service, especially in a seasonal cabin where the plumbing must be drained and winterized. The cap comes off without a fight, and the water goes out. These valves also has a strainer that keeps material like sand from interfering with the valve's operation. My water supply is gravity fed from a brook, and I have about 18 lbs pressure, so the adjustable valve isn't really needed for my application, but would be great for anyone who is on municipal water or a well.
Similar Threads: 1949 Eljer
Toilet Forum discussions Replace 1949 grey Crane toilet with...what? Jan 10, 2010
Toilet Forum discussions Eljer Toilet - no jet/wash down i think? total neophyte but learning Mar 19, 2017
Toilet Forum discussions Eljer toilet identification help? Aug 14, 2016
Toilet Forum discussions Eljer touch flush assembly. May 16, 2015
Toilet Forum discussions Eljer Toilet Without Siphon Jet Dec 7, 2014
