17" rough in with a space the size of Texas behind tank
Discussion in 'Toilet Forum discussions' started by Ruby, Jun 9, 2014.
  1. Ruby
    Ruby New Member
    Jun 9, 2014
    Just purchased our 1940's home and discovered that our toilet has a 17" rough in, and the previous owners have a 12' rough in toilet on it. We are looking into the Toto-unifit set up. ..Or is there something else we should be looking at? (and no, adding a cabinet behind the toilet isn't really the solution I am looking for).
  2. Terry
    Aug 17, 2004
    Right now there are very few bowls that can be moved back even two inches.
    The TOTO models with the Unifit, can be purchased with the optional 14" Unifit, which allows shifting the bowl 2"
    That still puts you out there a ways, but does give a bit more leg room while sitting.
    [​IMG]
    14" Unifit adapter
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    If the closet flange is readily available from your crawl space, you might be able to reasonably get your rough in changed to 12 inches. Consider posting an under-side photo (800 pixels max). Were you planning to re-do the bathroom floor? If so, think about moving the flange as part of that project.
  5. R1ck
    R1ck New Member
    Jul 8, 2014
    Is it possible to modify a Toto unifit out to 16"? from the photos I've seen, it looks like it's made from regular plumbing pipe...
    Rick
  6. jadnashua
    I think this would be risky. It might work, though. The siphon jet can only push stuff so far, and adding a couple more inches may be more than it can handle. The start of the flush has to get the entire length moving in order to create the siphon that then pulls the rest of the waste to follow it out and then down.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    While moving the flange would be the best option, there must have been a reason the original flange was roughed in at 17". In my opinion, altering the Unifit adapter would not be wise even if possible. The 14" adapter would be the best second option if the flange relocation proves to be unreasonably difficult. You'd be left with a 3" space behind the tank, but that isn't a great deal more than many toilets with standard flanges have. My Dartmouth sits on a 12" (exact) flange and has a 2-1/4" space between the tank and wall, so an additional 3" wouldn't be all that bad.
  8. R1ck
    R1ck New Member
    Jul 8, 2014
    The toilet is in a daylight basement unit in a condo built in the 60's, with the flange cast into the concrete slab. Relocating the flange would probably involve a jackhammer, not to mention the approval of the condo board...not gonna happen. All the toilets in the building were replaced several years ago with basic/cheapo 12 rough low flow units on a city utility program to reduce water usage. I think that the building was done with 16 rough throughout, 'cause everybody complains about how far the 'new' 12" toilets are from the walls...my speculation is that the original plumbing was planned by an old-school plumbing guy, since I've heard that 16 was more common 20 years earlier...
    I'll just get the Toto unifit 14. From what I've measured, the two inches going from 12 to 14, plus the dimensions of the Toto bowl front will give me close to 3" setback on the front of the toilet. Maybe I can finally re-hang the master bathroom door...
    Thanks
    Rick
  9. Gary Swart
    Sep 1, 2004
    Yakima WA
    I'm sure not an old school plumber, but there are some on this forum that are and I don't recall any of them ever mentioning that 16" was a normal rough in the the days of yore. Maybe HJ or Terry might expand on this.
  10. R1ck
    R1ck New Member
    Jul 8, 2014
    I saw something on another thread on this board about 16 rough being done in the 30's and 40's... I suppose that the other possibility is that after the rough was done, during the framing of the condo they moved the wall slightly for some reason... And it's not the space behind that's the issue - it's that the current 12 toilet on a 16 rough doesn't let the small bathroom door open fully.
    Rick
  11. Terry
    Aug 17, 2004
    In the 20's with tanks that mounted on walls, they used a 14" rough.
    There never was a 16" unless the framing was missed.
    As plumbers, we shoot for 12"
    Sometimes because wood is in the way, we wind up at 10" or 14", or close.
    On a concrete pour, things can get knocked around, or they might know exactly where walls will be framed.
    Often, the lower floor was left unfinished, and it was years later before someone decided to layout a room.
  12. Gary Swart
    Sep 1, 2004
    Yakima WA
    One more thing you might want to consider is changing the swinging door to a pocket door. This can greatly increase the usable floor space in a small room.
Similar Threads: rough space
Toilet Forum discussions Need Advice: 10-inch rough-in for small space Saturday at 12:03 PM
Toilet Forum discussions Toilet for SMALL SPACE with 10" rough. Dec 15, 2015
Toilet Forum discussions Looking for a small space toilet, 14" rough in, 28" depth or smaller Sep 21, 2015
Toilet Forum discussions Best options for 13 inch rough in and small space? Mar 12, 2012
Toilet Forum discussions No rough in yet, will 10" Unifit make more space? Dec 22, 2009
