1600 for powervent50 gal-is this high?
redshoe
Had a plumber quote me 1600 for a new 50 gallon bridge something or other power vent-(current heater richmond power vent ) this includes new tank, install, haul away and any changes with the lines/gas etc. Husband is freaked that this is too high but I think it seems rather reasonable especially considering he isn't home handy man.
GrumpyPlumber
Licensed Grump
Licensed Grump
Thats about the norm.
I know some companies that charge 1800, others go lower.
Be sure he'll warrantly his labor for a year if he's providing the heater.
You might have a 6 year MFG warranty, but that doesn't cover labor...that price should include a year for labor in the event anything small goes wrong.
heater
Call more than one company. If they all are in that range, then it makes no difference whether it is higher or lower than we would charge, because we are not coming there to install it.
Bob NH
New Hampshire
Is it a replacement or a new installation. That should make a big difference in the cost.
GrumpyPlumber
Licensed Grump
Licensed Grump
Actually, good point.
There's additional work for changing from draft type venting to powervented which can have completely different estimates depending on vent location/distance.
redshoe
It's a replacement-- sorry it's a bradford white 50 gallon power vent installed for 1600 total--replacing our courrent 40 gallon richmond power vent water heater. Repairman said the electronics were going bad and that it makes more sense to just replace the whole unit instead of trying to fix it--bummer because the heater is only 4 yrs old.
GrumpyPlumber
Licensed Grump
Licensed Grump
GET another opinion.
MACPLUMB
HOUSTON, TEXAS
Power Vent
:D
YES get a second opinion or call the factory at 1-800-heater3 that is RHEEM/RUUD water heaters that who makes your RICHMOND water heater,
they can give names & phone numbers of 1 or more plumbers who carry or can get replacement parts for your water heater,:)
the plumber who looked did not know or was too lazy to properly work on
your product so was taking easy way out, to install new wtr/htr and make more profit/money on this work:eek::(
JERRYMAC MASTER PLUMBER PH.D. WATERHEATEROLGY
MACPLUMB
HOUSTON, TEXAS
Power Vent
WHY SAME PRICE ? ? ?:(:(
I can rebuild just about any electrioncs on any power vent style wtr/htr
for under $500. parts and labor:D
JERRYMAC MASTERPLUMBER:)
MACPLUMB
HOUSTON, TEXAS
Power Vent
YES, YES, A VERY GOOD PRICE TO DO THAT !!!:)
BUT THIS IS A "FOUR' year old water heater ! !:eek:
but do you throw out ever 4 yr old water heater you see ? ? ?:confused::rolleyes:
JERRYMAC
MACPLUMB
HOUSTON, TEXAS
Power Vent
O. K. You Do What You Want To Do. I Am Sure You Change Out Many
Water Heaters Because You Do Not Know Or Care To Service Them???
I Am Sorry I Forget That Most Plumbers Don't Know How To Work
On Water Heaters If It Needs More Then Just A Thermacouple ! !
Jerrymac
GrumpyPlumber
Licensed Grump
Licensed Grump
"Dr." MAC is correct, thats why I stated get a second opinion.
I get a heat call, turns out to be a dead circulator, I don't sell 'em a new boiler.
Cwhyu2
Consultant
Cincinnati OH
Mostly they are dead Ihave 10 yr old w/h was 3yrs old when Ireplaced it.
Still working fine.New W/H and new codes make it neccesary to charge that much.
Master Plumber Mark
www.weilhammerplumbing.com
get a seconnd opinion
It really depends on where you live .....
In the midwest you should be able to get
a 50 gallon power vent Brad white for
somewhere around $1250....with a 6
year tank warranty
for a ten year unit figure $1500.00
the reason plumbers do not want to mess with
power vent water heaters is getting parts for an
older unit
sometimes its almost impossible to find parts
and when you
give them the bill they go nuts...........
would you be happy with a bill for 600 bucks to repair a
9 year old water heater???
