15 amp to 20 amp
Discussion in 'Electrical Forum discussion & Blog' started by ryan87500, Sep 8, 2008.
  1. ryan87500
    ryan87500 New Member
    Sep 8, 2008
    New York
    I am about to purchase a house with a 15 amp breaker in the bathroom and would like to change it to a 20 amp breaker. I know I have to rerun the 14 gauge wire to 12 gauge wire, but is there any requirements for neutral wires?
    I do not know the size of the neutral wire that is currently being used.
    Ryan
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Is this a cable instllation?
    The white is the same size as the black in a cable.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Just my opinion...if you don't know the answer to your question you may want to have an electrician do the work...
  5. jimbo
    jimbo Plumber
    San Diego, CA
    This is more complicated than you think. Assuming that breaker serves several receptacals and/or switchs, you would have to track down ALL the runs and branches on that circuit to ensure that NO 14 gauge wire remained.
    You did not tell us what you want to accomplish, but it sounds like it might be simpler to just install an all new 20 amp circuit into the area where you need it.
  6. ryan87500
    Sep 8, 2008
    New York
    I realize that I would have to track it down to all switches / receptacles and pull new wire to each one.
    What I want to accomplish is not getting yelled at by my wife when she trys to run her 1875 watt hair dryer and her hair straightener and keeps on tripping the breaker.
    The wire is run through conduit in the house and from what I can tell is they have a separate breaker that controls the 3 batrooms in the house.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    with a 1875 watt dryer and the other item plus the lights a 20A circuit may not work
  8. ryan87500
    Sep 8, 2008
    New York
    The current run only connects the outlets in the bathroom so with a 20a I believe I should be fine.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    how many watts is the hair straightener?
  10. ryan87500
    Sep 8, 2008
    New York
    It is 170w
  11. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    It may be easier to just buy a smaller hair dryer
  12. ryan87500
    Sep 8, 2008
    New York
    Is 15AMP standard for a house that is about 25 years old?
  13. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Yes
    Many homes only have a 15 amp circuit supplying the bath receptacle.
    Sometimes it is better to fit our lifestyles around what we have instead of fitting everything around us to our lifestyles.
    Edited to add:
    Portable electric heaters are sometimes too big for the circuit that supplies them.
    The question becomes, do I install a larger circuit for the heater, find a different circuit to plug into or just put on a few more cloths?
    This can also be said about the big blow dryers. Do I rewire the house to satisfy the hair dryer or do I find somewhere else to plug it in?
    The simple solution is to get a smaller dryer.
  14. ryan87500
    Sep 8, 2008
    New York
    I agree that is the best option.
    Just for curiosity sake does the neutral wire gauge have to match the hot wire gauge.
    Thanks
  15. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    YES unless it is a deversified load such as a range service dryer ect,,,
    All 120 volt circuits will need a neutral neutral the same size as the hot conductor.
  16. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Conduit in your house? Sweet:D
    Pull in a couple of #12's and install a GFCI outlet. Leave the other wiring intact/fed thru/capped off.
  17. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    This would be my exact advice as well.
  18. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    You both agreed!!
    WOW!:D
  19. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I know. I was trembling as I was typing that. :eek:
  20. ryan87500
    Sep 8, 2008
    New York
    Wouldn't that method depend on if I have enough room in the conduit to run 2 more wires?
    Here is a picture of the open junction box, the blue wire is the 14 gauge wire to the bathroom.
    [​IMG]
