14/3 Uses
Discussion in 'Electrical Forum discussion & Blog' started by dlarrivee, Apr 6, 2011.
  1. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Is it out of the ordinary or not allowed to switch (2 switches, 2 gang box) both the black hot and red hot conductors with 14/3 cable?
    I'd like to run power to the 2 gang box from the panel, then run 14/3 from the 2 gang box to the vanity light, and from there 14/2 for the exhaust fan.
  2. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    Sounds good,
    On my work I would generally run 14/2 on the power leg and 14/3 on the switched legs. Gave me the option of switching lights and fans separately, also made it easier to wire up the boxes if I had a 14/2 I knew it was the power into the box, and if I had the 14/3 I knew it was going out of the switch to the fixture.
    Michael
  4. dlarrivee
    Jun 28, 2009
    Canada
    That is exactly what I'm planning to do, I figure it would be a cleaner installation that way. I only need 2 feet of 14/2 to go from my light box to my fan this way...
Similar Threads: 14/3 Uses
Electrical Forum discussion & Blog 14/3 strange usage Feb 20, 2012
Electrical Forum discussion & Blog Reversed Polarity - Fix Causes Buzzing Noise and Burning Smell? Dec 28, 2016
Electrical Forum discussion & Blog Houses built with rigid conduit Sep 1, 2013
Electrical Forum discussion & Blog Can Screw In Fuses be Safe If Sized Correctly? Aug 25, 2013
Electrical Forum discussion & Blog Fuses getting very hot in Fusebox Jan 23, 2013
