14/3 strange usage
Discussion in 'Electrical Forum discussion & Blog' started by MrBillyd, Feb 20, 2012.
  1. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Earth is a good Ground if the voltage is high enough, and that proves it.
    The Power Utility company is the only one allowed to use the earth as ground/neutral, as far as I know.
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Oh and Samuel Morse did too, right?
  3. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That was before AC was used.
    DC was tried before they figured out AC was better for transmitting.
    Later Morse used RF, so it was AC. Just not 60hz, Subs used that frequency.
  4. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    I rarely smile. The last time I remember feeling one come upon my face was about eight years ago when I was informed of my mother-in-law passing.
  5. BobL43
    Mar 25, 2011
    Long Island, NY
    Those Colorado Winters didn't give you that cold heart did it? Just kidding (or am I?). I guess I was lucky, I had a great Mother In-Law. If everybody had a Mother In-law like I had, there'd be no mother in-law jokes. That'd be no fun though
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    lol
    That made me smile.
  7. Steve Jones
    Steve Jones New Member
    Feb 15, 2015
    Maryland
    I've got another "questionable" use for 14/3 that I'd like an opinion on.. I wanted four outlets, each switched by a different switch, in close proximity... Rather than run four 14/2 wires, I ran two 14/3, and split the hot on each of two dupex outlets (broke the bridge on the side of the plug..) and used the red as the hot for one outlet, and the black for the other... All four plugs come back through a 4-gang box with four switches, and then all to the SAME 15 amp breaker.
    I can see that if I was to expect to get 15 amps out of each outlet, I'd obviously pop the breaker, but since these are all on the SAME 15 amp breaker, I think what I've done is safe and to code, since it's not logically any different than a 4-outlet power strip, except that I have switches on each outlet.
    I hope this makes sense... Is there anything dangerous I'm missing here?
    FWIW, the purpose of this was to plug in four arcade/pinball machines, which each probably take no more than 2-3 amps, but I wanted the switches all by the door to the room so I didn't have to fumble around for the individual power switches on the machines.
    -Steve
  8. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    You are OK IMHO, if you run 14/2 to the 4 inch box from the breaker to the 4-gang box. If you are talking about running 4 hot wires to the breaker, that sounds like it might violate some rule that I don't know about regarding overfilling the terminal on the breaker. Not a pro.
  9. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    I think you did good.
  10. hj
    IF both 120v loads were EXACTLY the same amperage, you would not need the neutral because they would divide the 240v power. I have done a similar thing when I had to temporarily use 240v elements in a 480v water heater.
  11. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    I have a great Mother in law also.
    She lives 7 hours away!
  12. hj
    They say there is only ONE lawyer joke, the rest are all true. Sometimes MIL jokes could be the same way.
Similar Threads: 14/3 strange
Electrical Forum discussion & Blog 14/3 Uses Apr 6, 2011
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog Strange electrical experiences Apr 1, 2016
Electrical Forum discussion & Blog Strange Voltage Drop When Light Bulb is Installed Aug 8, 2015
Electrical Forum discussion & Blog Strange Ant Problem - FYI May 22, 2015
