110v or 220v??
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mycard00, May 24, 2006.
  1. mycard00
    mycard00 New Member
    May 24, 2006
    old submersible was pulled and replaced both were 220v.?? is old pump was taken apart and fixed for a portable pump ie to pump water from a pond to a pool i think it might have been wired 110v. how do check the voltage needed to run this pump??? :eek:
  2. Cass
    Cass Plumber
    Nov 12, 2005
    There should be a tag on the side that gives HP,voltage, amps, ect.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    "old submersible was pulled and replaced both were 220v.?? is old pump was taken apart and fixed for a portable pump ie to pump water from a pond to a pool i think it might have been wired 110v. how do check the voltage needed to run this pump???"
    If I understand your question properly, a 220 V well pump was adapted to be used as a portable pump.
    I have never seen a submersible well pump that could be rewired for a different voltage than it was built for. If it was a 220 V motor, it is probably still still a 220 Volt motor.
    If it is a submersible well pump motor, the information is probably etched on the side.
  5. mycard00
    mycard00 New Member
    May 24, 2006
    110 or 220 volt
    thanks fellows found stamping and its is 220v thanks again :)
Similar Threads: 110v 220v
Pumps and Tanks Well Forum & Blog. Water is life. Sta Rite 4" 110v 2 wire Deep well Pump Aug 31, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Connecting 220V Stenner pump Sep 30, 2013
Pumps and Tanks Well Forum & Blog. Water is life. wiring 220V Stenner pump to pressure switch Jun 23, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Myers 220v 1.5HP Pump No Flow Jun 22, 2008
