11" rough-in
Discussion in 'Toilet Forum discussions' started by joelprice, May 7, 2010.
  1. joelprice
    joelprice New Member
    May 7, 2010
    I have a 11" rough-in and want to know if the 12" Toto Aquia III I ordered will work? I know, I should have measured first before ordering.
    Any ideas or suggestions?
    Thanks.
  2. Terry
    Aug 17, 2004
    The Aquia III needs 11.5"
    The Drake needs 10-7/8"
  4. joelprice
    May 7, 2010
    Thanks... Terry. If I was able to get a 10" Aquia would that work? Do you know of anyone in the San Diego area who has the 10" Aquia in stock?
  5. Terry
    Aug 17, 2004
    The CST412MF.10 would work.
    I don't know about San Diego, I work with an outfit in Claremont, they go down to SD once a week, but they charge $50 for that.
  6. sdradius
    sdradius New Member
    Jul 12, 2010
    San Diego, CA
    11 3/8" Rough-In?
    I have a 11 3/8" rough-in. I would go with the CST744SF.10 but it only comes in universal height and I prefer it lower.
    So the Drake will work with a 11 3/8" rough-in? My remodeler is concerned about the fit. Do the CST743S and the CST744S both require the same amount of space?
    Thanks!!
  7. Terry
    Aug 17, 2004
    They work at 10-7/8"
    If you see an old pdf, it's just that, old.
    The CST744EF.10 would stick out from the wall 2"
  8. sdradius
    sdradius New Member
    Jul 12, 2010
    San Diego, CA
    Thanks Terry! Do you know if I can find a PDF somewhere that says that? It would help me to prove that it will fit.
  9. Terry
    Aug 17, 2004
    We install them. Hundreds of them. I'm not going to bother making a pdf for you saying that.
    If you don't believe someone that has installed hundreds, then you might as well pick up the 10" rough and have it set out 2" from the wall.
    Free advice is given freely, but I'm pretty busy to be making diagrams of things I've been doing for years.
    I know what works from experience, if your handyman needs documentation for something as simple as the installation of a toilet, perhaps he's in the wrong field.
  10. sdradius
    sdradius New Member
    Jul 12, 2010
    San Diego, CA
    Thanks Terry. I'm also considering the UltraMax. You had said elsewhere the UltraMax requires a 11 1/4" rough-in. Does that mean with a 11/4" rough-in, the tank would actually be touching the wall?
    Thanks again!
  11. Terry
    Aug 17, 2004
    Yes,
    The tank would touch the wall with the Ultramax at 11-1/4"
  12. Amybchen
    Amybchen New Member
    Jul 30, 2010
    CA
  13. sdradius
    sdradius New Member
    Jul 12, 2010
    San Diego, CA
    And Terry is correct. Thank you very much!! The Drake fit just fine with the 11 3/8" rough-in. The installer said it was tight, but worked, and there's plenty of space to the wall. There's actually more space to the wall than with the previous toilet.
    So if anyone has a 11 3/8" rough-in and is concerned, here's a testimonial that it worked. Thanks again to Terry. Saved me from having a Wellworth installed. :)
Similar Threads: rough-in
Toilet Forum discussions Toilet Rough-in a tad short? Help?! Sep 17, 2015
Toilet Forum discussions need help with 10" rough-in toilett Sep 2, 2015
Toilet Forum discussions Toto Aquia II - Rough-in Problem Jul 6, 2015
Toilet Forum discussions Advice to first time DIYer replacing 14" rough-in toilet? May 24, 2015
Toilet Forum discussions Considering several Totos -- which will fit 11" rough-in? Apr 9, 2015
