Blade_Jones
Do they make an 11 1/4 degree ABS elbow (4")? I am replacing a section of sewage main. I don't want to drop the depth using two 90 degree elbows, so I can either use a rubber 4" coupling OR preferably find a 11 1/4 elbow if they are even made. I have found that 4" PVC elbows are made (in the 11 1/4 degree size), but can't seem to find any ABS elbows in uncommon sizes. Can I use a PVC elbow for a sewage drain (mixed with ABS)? If so can I use ABS pipe cement on a PVC elbow? Will it hold up?
