#10/3 for single wall oven?
Discussion in 'Electrical Forum discussion & Blog' started by Artie, Jan 4, 2010.
  1. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    I just want to make sure before I do this. This is a low-line Kenmore singe wall oven. Spec plate in door says: 120/240 3.4Kw. Installation guide calls for a 30-amp breaker. 10/3 is rated for 30 amps. Approximately a 20' run.
    Does this sound ok, or should I go for #8/3 or #6/3?
    Btw, thats 10/3 w/grnd.
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    10/3 is fine.
    Most single wall ovens are a 120/240v-30A circuit.
  4. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    Thanks Pete. Now I know why they call you "speedy". ;)
  5. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    At the last minute, I decided to upgrade to 8/3 w/gnd. There will be about 12' that will run through the attic, (going across a now-enclosed carport roof), here in a Florida home. NEC 310.15 (A)(2) says something about reduced ampacity if a high-temp section exceeds 10 ft.
Similar Threads: #10/3 single
Electrical Forum discussion & Blog How To Wire Single Pole Light Switch with Pilot Light Dec 11, 2014
Electrical Forum discussion & Blog Converting Two Recessed Lights on a Single Switched Leg Jun 16, 2014
Electrical Forum discussion & Blog a single 3-way switch controlling a light fixture on a knob & tube circuit - why? Jun 12, 2014
Electrical Forum discussion & Blog Can I use 2 single pole 30 amp pushmatic breakers as a double pole set up May 28, 2014
Electrical Forum discussion & Blog Multiple lights/switches on single circuit. Aug 30, 2013
