1'' polypipe as the drop pipe
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by luc, Feb 16, 2010.
  1. luc
    luc Member
    Apr 19, 2007
    Quebec, Canada
    Hello everyone,
    Just want to know if it is good practice to use 1'' polypipe as the drop pipe in wells with 3 HP or 5 HP submersible pumps.
    Thanks,
    Luc
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    That be a bit much HP to be setting on Poly
  4. luc
    luc Member
    Apr 19, 2007
    Quebec, Canada
    What is usuallly used for drop pipe on 3 to 5 hp pumps?
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    PVC, or Galvanized. I hate Galvanized though because it rusts
  6. luc
    luc Member
    Apr 19, 2007
    Quebec, Canada
    Thanks Peter for replying.
    I read on a previous post that even PVC was not reccomended for pumps greater then 2 HP!!!!
    Luc
  7. ballvalve
    Dec 28, 2009
    northfork, california
    Schedule 80 pvc with the SS couplers should hang 5hp dependant on depth. I would email the pipes MFG and not take the point here. I have 3HP on 200psi poly @200 feet, but you must use long,drawn brass fittings with three to 4 real clamps with a sae torque rating. You would have to also heat to insert the pipe on the fittings using the MFGR's instructions, not the local barefoot plumbers torch method. I woulod also reheat the pipe the next day and retorgue the clamps before setting. If using a 5 hp pump a slow start would solve all torque issues.
  8. luc
    luc Member
    Apr 19, 2007
    Quebec, Canada
    Thanks ballvale for replying. It answers my question.
Similar Threads: polypipe drop
Pumps and Tanks Well Forum & Blog. Water is life. Help removing polypipe from brass barbed fittings... Aug 23, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Seal Cap and/or Drop Pipe Supports/Hangers Dec 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Can I replace galvanized drop pipe in 2" well with black poly? Dec 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Dug well - pressure drops to zero within minutes. Any thoughts? Nov 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure dropping, breaker tripping Oct 28, 2016
