1 pole, 2 wire or 2 pole 3 wire switch for water heater?
Discussion in 'Electrical Forum discussion & Blog' started by bigtime, Nov 4, 2007.
  1. bigtime
    bigtime New Member
    Nov 4, 2007
    This is probably a dumb question, but...I am installing a disconnect on the water heater to turn it off when I am gone, which is about ALL the time. :) I thought I knew what I needed, a 30 amp switch. Sounds simple enough. The problem is this, I found a website that has 2 different 30A indoor switches. One is a 2 pole 3 wire and the other is single pole, 2 wire. Both with solid neutrals. The single pole, 2 wire is only 19.99 and the other is 31.99. They both say they are for water heaters. So which do I need???
    Could someone also explain the difference? I am sure once its explained to me it will make sense, but right now its driving me insane! Thanks!!!:D
  2. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Electrical Contractor
    I don't understand the 'solid neutral.' It is a code violation to switch neutrals (unless you are wiring a gas station).
    What you need is a 2-pole 30a switch. Another term for it is a Double-pole single-throw.
    Can you provide a link to this website your found?
  4. bigtime
    bigtime New Member
    Nov 4, 2007
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    The 19.99 one is fine.
    wait...it's not
    Although I have never seen one, it implies that it's a single pole (120v) switch.
    The one next to it says unfused but the description says "cartrige fuses".
    A pullout style is only 15 bucks but you can only enter it from the bottom portion.
    Top left..AC disco
    http://search.hardwarestore.com/?query=pullout disconnect&tId=257
  6. 480sparky
    Oct 8, 2007
    Their descriptions don't make sense. They say it's a 1-pole, but it's for 240 volts. 240 requires two poles in order to be a disconnect.
    By the time you figure out what you want with an online store, plus pay shipping & handling, you could have it done if you buy locally. I'd say just head down to your local hardware store or home center and pick one off the shelf.
  7. bigtime
    bigtime New Member
    Nov 4, 2007
    I almost bought a 30A pullout style from my local hardware, but a switch style seems like the better way to go. No pullout thingy to lose. Sure you shouldn't lose it, but ya never know. The last thing I want to do is not be able to take a shower because the pullout I swore I left on top of the water heater has suddenly "walked off!"
  8. 480sparky
    Oct 8, 2007
    Most pull-out style disconnects are made to accept the 'loose part' in an 'off' position. You just pull it out, turn it 180°, and reinsert it.
    BTW, is turning off the breaker not an option? If you can do that, you'll save yourself the time & money to do this.
  9. bigtime
    bigtime New Member
    Nov 4, 2007
    Turning off the breaker is totally an option, its what I have been doing. I just remember reading on another forum that breakers are not meant to be used as switches and you will wear them out, etc. Not sure how true this is, its just what some internet "expert" said.
  10. 480sparky
    Oct 8, 2007
    Some breakers are rated to be used as switches. Can you provide the details on the brand and such? If nothing else, you may be able to replace the breaker with one that is switch rated.
  11. bigtime
    bigtime New Member
    Nov 4, 2007
    The breakers are square D homeline.
  12. 480sparky
    Oct 8, 2007
    Square D Homeline breakers are rated SWD for use as switches. If you can find those letters on the breaker, it's made to be switched. If not, just purchase a new on that is so marked.
  13. bigtime
    bigtime New Member
    Nov 4, 2007
    They sure are marked "SWD", I just ran down and checked. Thats what I will do then, just keep turning it off there. Thanks so much, saved money and learned something new. Thats a good day. :D
Similar Threads: pole wire
Electrical Forum discussion & Blog How To Wire a Square D QO220GFI 240v, 20-amp Double Pole Breaker Jan 26, 2015
Electrical Forum discussion & Blog How To Wire Single Pole Light Switch with Pilot Light Dec 11, 2014
Electrical Forum discussion & Blog Two pole arc fault breakers for multi wire circuits Jan 6, 2014
Electrical Forum discussion & Blog Advice on feeding house panel from pole mounted meter 200a Aug 28, 2016
Electrical Forum discussion & Blog 120v w 19 gallon water heater run on 2 pole 230v breaker. is it safe? Jul 9, 2015
