1" PEX or 1" PVC when hooking up new softener?
Discussion in 'Water Softener Forum, Questions and Answers' started by JoshB-NC, Oct 22, 2012.
  1. JoshB-NC
    JoshB-NC New Member
    Sep 20, 2012
    North Carolina
    All the current connections and piping in my well house are 1" PVC. The softener and Filox filter are both 1" pipe connections. I have been told by numerous people to use PEX instead of PVC. I have the pex tool and I have done plumbing with both. Its just that the ID of the pex is quite a bit smaller than PVC. Does it matter??
    Its a well system JRD10 pump 30/50psi.
  2. Terry
    Aug 17, 2004
    PEX handles heat better. PVC is rated for use underground.
  4. JoshB-NC
    JoshB-NC New Member
    Sep 20, 2012
    North Carolina
    The well house has the jet pump and bladder tank all plumbed with pvc. The pvc then goes through the slab of the well house under ground 80' or so to the house.
    I was going to use 1" pex from water pump to filter and softener then tie back into the larger 1" PVC where it exits the pump house.
    I just want to make sure I am not going to lose volume or pressure inside our house because the 1" pex is quite a bit smaller than 1" PVC (ID).
    Maybe its a dumb question? I just want to do it right!
  5. Terry
    Aug 17, 2004
    PEX is smaller, so for a water service many people recommend bumping the size to 1-1/4"
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Ya can't use PVC inside the house but you can in the well house (go figure) so since everything else is PVC you might as well stick with it.
  7. Gary Slusser
    Retired
    PVC is much easier to use and less expensive overall and that's what you already have. I'd use PVC.
  8. JoshB-NC
    JoshB-NC New Member
    Sep 20, 2012
    North Carolina
    Ok thank you!
Similar Threads: hooking softener
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Softener resets and reloads about every three days Feb 11, 2017
Water Softener Forum, Questions and Answers Softener, Just need some advice and help... Feb 9, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
